Question about Sony DCR-DVD608E DVD Camcorder
Disc wont finalise
Hi, I've recorded using my camcorder, except it wont give me the option to finalize the disc... every time i place the disc into the camcorder it comes up with the format menu... If i format the disc will i lose everything?? please help!!!
  • 2 more comments
  • natnotnat Aug 16, 2008
    Its a DVD-RW
  • nandu snake Sep 08, 2008
    i have done my recording and when i click the finalize button in the menu, it displays "This function is not currently available". I'm having so much problem with this.
    thankyou for the solution.
  • rameshg Sep 29, 2008
    I'm using SONY -RW cd,while I try to Finalize the DVD I'm getting the messgage , The Function currently not avilable. Pl suggest me to do the Finalize !
  • Tim Babcock
    Tim Babcock May 11, 2010
    What type of DVD do you have in there?
  • Sony Master
  • 2,794 Answers
I'm only able to get the manual in Spanish
Here is a copy of it and you will see
I can't read it. Learning Spanish is on the to do list.
Posted on Aug 16, 2008
My disks are DVD-RW and want tp use them over gain and don't know how. Also when do I finalise then and what for
For RW discs, you need to reformat them to reuse them. For your laptop, you should see a format option if you right click on the DVD icon when you have the File Explorer open to Computer (My Computer). (This assumes that the computer has a DVD writer.)
Finalizing the disc enables the contents of the disc to be read on other DVD players. (This isn't always an issue. For example, a disc burned with WinXP should be readable for a computer with Windows 7 without finalizing. However, if the disc was burned by a DVD player, the contents will not be accessible on any other units without being finalized.)
If the disc has been finalized, you need to take another step before reformatting the RW disc. Put the disc in the unit that initially finalized it. Then look for an Unfinalize option. Then format the disc again. (I've never used this feature on my computer. It's easily accessed on my DVD recorder in the same section of the submenu as finalizing the disc.)
I hope this helps.
Sep 12, 2011 | Computers & Internet
DVD Recorder is ruining the DVDs
Here is the link to the manual for LG DR1F9H
read pages 33&34
you may be using wrong
disc or wrong mode
Dec 13, 2007 | Televison & Video
My camcorder will not give me an option in disc operations to finalise a disc which I recorded on (which I did initialise before starting- I have also tried it on another disc, initialise, record etc) I...
Are you using the AC adapter when trying to finalize? You cannot finalize using battery power only.
Link to your manual:
Canon DC210 Manual
(What format discs are you using?)
Instructions for finalizing begin on page 61.
Hope this helps.
Thanks for using Fixya.
Mar 11, 2011 | Canon DC210 DVD Camcorder
How do i finalise the double sided disk so it will download onto my computer? My computer wont pick up solution disk either? I know that anithalize delete's it!...
Finalize disc in camcorder while powering it with supplied ac charger/ adapter. Camcorder has option for that.
You can not finalize disc in computer that was recorded on camcorder.
Jun 19, 2010 | Canon DC220 DVD Camcorder
The display says 'red disable' then afetr a sort while goes to the flashing disc full symbols. My problem is that it won't let me finalise so can't save the data and use the disc on other things like my...
Do you get finalize option as grayed/ disabled?
If yes then plug ac power adapter in camera and finalize the disc.
Camcorder wont finalize on battery and need ac charger to perform finalize the disc.
Jun 03, 2010 | Sony Handycam DCR-DVD201E DVD Camcorder
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Finalising discs with canon camcorder
I do know that to finalize discs, you need to have your camera plugged in to a wall outlet, according to the owner's manual.
Jun 07, 2009 | Canon DC210 DVD Camcorder
How to view DVD rewritables
Petra
Had the same problem, You have to press the mode button down which changes it to play and brings up the frames in the viewer. Then select Func, it will then give you a menu screen that shows finalise. What the manual does not say is press down the mode button to get the camera in play mode, when you do the gree light for play comes on.
Hope this helps
Feb 04, 2008 | Canon DC220 DVD Camcorder
Unable to finalise
For some reason one of the discs that i have recorded on will not let me finalise. When i put the disc in it says recording disabled and then i go to the finalise menu and the finalise selection is unhighlighted. How can i fix this so i can finalise the disc and use it on my computer?
thanks
Oct 28, 2007 | Sony DCR-DVD602E DVD Camcorder
Sony DCR-DVD608E DVD Camcorder Logo
137 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
