Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Which way does the motor go back in correctly in my bissell power steamer powerbrush model 1694? i took it apart to clean and didnt mark how to put back in
SOURCE: my bissell powerbrush won't **** up the water
had same problem - carpet soaked with dirty water and very little, if any, cleaning fluid used. Easily remedied. Removed water resevoir and found that the rectangular shaped washer at the top of the front cover (the bit you had unscrewed to give a good clean) had become dislodged. It has small lugs on either size which lock on to the plastic opening when pushed down firmly. Resevoir then sits on top and makes full connection, also ensure that grey locking handle is fully pushed down.
Seemed to me that the water wasn't being sucked up as there was air getting in and this has down the trick. Sorry if this is difficult to follow but all will become clear when you look for the black washer! Good luck
Posted on May 04, 2009
  • 384 Answers
SOURCE: Bissell Powersteamer 1694-W Roller issue
sound like a motor problem
Posted on May 07, 2009
Vac Belts
  • 701 Answers
SOURCE: I had a belt break on the bissell 1694-w power
Yes they are easy to replace. Here are the belts you need:
Bissell 1694 Belts
Posted on Feb 16, 2010
VacuumRepair
  • 438 Answers
SOURCE: i took my Bissell Powersteamer Powerbrush Deep
Here's a picture of the tubing on the PowerSteamer from an overhead view. I hope this helps you putting the machine back together. I know personally how challenging this repair can be, this picture really was my Bible when I was putting back together the machine for the first time. If you have a question about a particular tube, please feel free to add a comment to the repair page, and I'll be more then happy to answer any follow up question that you may have. If this was helpful to you, please be so kind and follow the Fixya model and rate the repair helpful by clicking the 4 thumbs up icons in the top right hand corner. This is greatly appreciated.
Here's the picture for you:
Chris Jones
GoVacuum.com
Posted on Apr 15, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell Power Steamer Proheat Plus not dispensing
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dfsghs
Posted on Sep 30, 2010
My PowerSteamer PowerBrush Deep Cleaner 1694-W wont spray water
Well what I had to do was replace the pump motor you will have to take it apart and look to see if it has ant rust then look at the pump witch it is a white canister looking thing see if it ceased up and then use 3n1 oil or wd40 on it and work with it tell it is free spinning! Then it will work
May 03, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell proheat 2x 8920 brushes aren't working
heatman101
gjkklgj
Dec 27, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
How do i put belts on a bissell powerbrush steam cleaner?
If this is the model i'm thinking of. Make sure the units unplugged from the wall. There should be about six phillips head screws to remove. The motor should now be exposed. This is a good time to clean up the inside of the unit. Use liquid wrench or WD-40 and lubricate any moving parts. Make sure the brush is in good shape some require you to rotate or flip the brush to even out the wear. I hope this has been helpful.... : )
May 07, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Manual for Bissell Powerwash Deluxe cleaner
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Mar 17, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell steam shampooer
There is a lint screen, but not really another filter per say. But you may have a stretched pump belt. Here is a link to your manual at the manufacture's web site. This link is only to YOUR manual so I am not suggesting any particular place to purchase from. http://www.bissell.com/images/UserGuides/1694-8806_607.pdf
When you look in this manual, on page 11 you will see the common wear parts on your machine... it's a good idea to have extra belts around incase you are having now.
I hope this helps.
Jan 20, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Powersteamer powerbrush
Brand new out of the box and the bucket didnt fit flush and the shampoo or water not spraying?
Mine was the same lift up the bucket and look at the rubber washer / seal take it off turn it inside out and put it back on.
Wahoo the busket fits the was washes , you have your carpet cleaner back
Jun 26, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
