Question about Sunbeam Classic 3964 Iron with Auto Shut-off
Como desarmar una plancha sunbeam mod 3964 - Sunbeam Classic 3964 Iron with Auto Shut-off
Sunbeam iron 5900 2400 watt not become hot. Now what can I do?
opps sr 5900 2400 watt have mixed consumer confidence
http://www.productreview.com.au/p/sunbeam-ultura-sr5900.html
if the dial or iron wont heat up at all
most sunbeam irons have 12 month warranty
if less than 12 months old and you have the reciept
take it back for refund or exchange
if out of warranty toss in the bin...... buy a new iron
Sep 20, 2016 | Sunbeam Irons
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
Cambiar cable ac
www.laundry.manualsonline.com has free manual
Apr 08, 2014 | Sunbeam Classic 3964 Iron with Auto...
TENGO I PLANCHA DE ROPA SHARK LIGHTWEIGHT PERO NO SE CUANDO ESTA LA TENPETRATURA al maximo nivel
La plancha tiene dos botones uno para sacar el agua y otro para el vapor y antes de esos dos tiene uno que cuando usted lo precione se mueve la temperatura
Jan 28, 2013 | Euro-Pro Shark Rapido Electronic Iron -...
I am looking for a manual for a Singer Magic Steamer 7.
TENGO UNA PLANCHA MSP7, LA CUAL PRENDE PERO NO CALIENTA, AQUI EN PARAGUAY NO HAY QUIEN ARREGLE, NECESITO SABER SI DISPONEN DE PLANOS ELECTRICOS Y DESPIES DE LA MISMA, DESDE YA MUCHAS GRACIAS.
MI MAIL ES:
sabatel2010@hotmail.com
Dec 30, 2010 | Singer Electronic Steam Press
Sunbeam Electric Blanket Model 972 A5 Type 692 (or 592) with temperature control 1 to 9 with 75 mins and 12 hrs and off control positions. The light blinks red and the blanket won't heat up. Please...
Did you get helped last year? If so please ignore. Otherwise....
Hi. You can locate a Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
You're looking at $69,95 recommended retail.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
Apr 08, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
Iron no longer has steam function
If you are using tap water then the hardness of the water could cause the problem. You can usually fix this buy running vinegar water through the iron once or twice like you would a coffee pot.
If you have been using distilled water then you probably need to replace the iron.
Jun 25, 2008 | Sunbeam Classic 3964 Iron with Auto...
Water leaking from iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Feb 06, 2008 | Sunbeam Classic 3964 Iron with Auto...
Sunbeam Classic 3964 Iron with Auto Shut-off Logo
691 people viewed this question
Top Sunbeam Irons Experts
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
