Question about Metra 95 96 Chevy Truck
I have a 1992 chev 4x4 305 truck that blew out the frost plug. How do I replace it as there is very little room to work-oil filter is in the way.
    Master:
  • 752 Answers
Take the oil filter out. Get a screw in plug.
Posted on May 25, 2011
  • 23 Answers
If you can gain better acces by removing filter then do so. If you cant access it then you can try using a rubber plug. Most part stores sell a rubber expanding plug that installs easily by removing old freeze plug and simply putting new one in hole and tightening the nut in the middle
Oil will not drain from my 78 yamaha xs750se
check the drain hole isnt blocked with silt , poke it ! also i think your over filling the engine with oil , does it have a dip stick on the filler cap or is there a sight glass on the side of the engine case on the same side as the filler ?
Mar 17, 2014 | 1978 Yamaha TX 750
Locating a frost plug
not knowing this particular engines anology, most freeze plugs are in the sides and rear of the block..and in the heads in some cases..why.. you seeing green liquid..and where..
Dec 24, 2013 | 1992 Cadillac DeVille
What releaf valve is under the oil filter chev 4.3 v6 4x4 s10
That is the filter bypass valve. If the oil filter plugs up then oil pressure opens the valve to let unfiltered oil back into the engine so it won't destroy the engine.
Jul 26, 2011 | Chevrolet C1500 Cars & Trucks
Oil pressure gage keeps dropping to zero
just finish doing a freinds truck same problem
engine high idle oil pressure ok engine at low idle hot
o oil pressure also hard start start after sitting a few minutes hot
or in am cold
found 1- wrong oil filter--not depresing dain out valve to crank case
2- oil cooler by pass valve rubber seal ruptured (fairly expensife oil filter base kit )
(only way to get this rubber)
3- found oil gallery plug pop out of oil injection pump(cant buy)
located small frost plug kit installed and peen area
reassemble and test all work out properly
4-could also be the oil gallery in the block at front or rear
they are also block of with frost plug cap
very pore desine should be treaded plug and locktite
Nov 02, 2010 | 2004 Ford F350
How do i remove the altenator from a 1992 saab 900?...i can't get the bottom bolt out!...thanks...sean
Unfortunately this is a very tight space to work in.There are a couple of bolts holding the bracket against the engine block.You need to remove those bolts and then swivel the alternator with the bracket still attached to it.You will then have room to remove the bottom bolt.You need to remove the oil filter and oil filter housing first.PLEASE REMEMBER TO REINSTALL THE OIL FILTER AND HOUSING BEFORE STARTING THE ENGINE.
Oct 11, 2010 | 1992 Saab 900
Oil leaking where oil filter attaches, but not from filter. Leak seems to be from the part where the filter attaches. this is 1992 chev 4x4 k1500 5.7.
Try this website for resolving car problems by downloading a FREE service manual for your vehicle. This is not an owners manual but a factory mechcanic's manual.
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
May 01, 2010 | 1992 Chevrolet C1500
Have a 1999 Z71 chev truck with 5.3 L engine that has fluctuating oil pressure. Started with low oil pressure after start with engine clak that disappeared after it warmed up. Changed oil and found sludge...
In some cases where the oil is not changed properly, the oil pump screen maybe plugging or your oil filter is defective. Fram is a good filter. If there is no problem found, replace the pressure sensor.
Jul 17, 2009 | 1999 Chevrolet Silverado 1500
My 1992 Ford f150 failed emissions test co was to
theres 3 things ur emisans fail on 1 spark plugs 2 air filters need changing 3fuil filter so yes a full service should do it change ur oil fuil filter air filter oil filter and oil
Mar 04, 2009 | GMC Yukon XL Cars & Trucks
1992 C1500 5.7L Hesitates when I push on the gas pedal.
I had that problem with my 1990 chev 2500 and it was a bad tps (throttle position sensor) it also has a 5.7L.
hope this helps!
Feb 20, 2009 | 1992 Chevrolet C1500
Change Oil Filter
On the bottom of the engine towards the back of the engine block, on most chev's it is on the drivers side.
Dec 11, 2008 | 1992 Chevrolet Suburban
Metra 95 96 Chevy Truck Logo
56 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Jason
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
