Question about ElectroVoice SxA180 Subwoofer
Help repair EV SxA180 sob woofer
I need schematic for SxA180 Sub woofer or what is the part number of power transistors they use?
Q10&Q10B IRF6215 Q11 IRF3315
Posted on Jan 09, 2009
  • AJ Vincelli Jan 03, 2014
    Wow, I have no idea how you knew the transistor numbers but good job! I need Q10, Q10b and Q11 fets for a Boston Acoustics MCS130 subwoofer, any idea if they are the same part numbers? I thought the Q11 part was IRF9640, but I could be wrong. Hard to read. Thanks for the help!
    New Friend:
Which is the Transistor number q10
Posted on May 27, 2014
Telex EV SonicXS Computer Speakers Not turning on
Hello harisoza, check for power amps, and fluctuation on that room. or entire home, . sometimes this lead to this kind of problems.
Carl
Jun 21, 2012 | Sonic EV SonicXS 4.1 Computer Speakers
Power unit (sub woofer) does not power up
If no lights are on then the defect is hardware: a part inside the power source of the subwoofer has failed. The only way to fix that is to open the unit, extract the power source, test it, identify and replace the failed part - most likely it's the switching transistor, it will cost you $10 a new one. Luckily it's a very simple source with a very simple problem that can be fixed by all repair shops - take your unit to one of them, all (including labor) will cost you less than $75.
Dec 16, 2010 | Audio Players & Recorders
Which circuit is used in sub woofer
the circuit for sub woofer consists of a transistor in parellel to the capacitor to supply power and moreover other I.C's or transistors depending upon the size of the sub-woofer achintya1915.jpg
Dec 06, 2010 | Office Equipment & Supplies
Electro voice ma-1212 shorted 2sd5200 power transistors
Your best bet would be to contact EV. Search for either EV or Telex. Telex will be easier to find and contact the repair department. Ask for the part availability and cost. They are very helpful there. Please let them know the model number as well.
Dan
Apr 16, 2009 | ElectroVoice...
Power supply board on GE 24GP453 TV
This is part # 260527 and is still available for $3.55.
I was not able to locate an ECG sub.
Dan
May 15, 2008 | GE 24GP653 24" TV
Harman Kardon 595
Hi, probably two things that can go dead, 1) the woofer itself and/or 2) the amplifier. I will rule out poser supply cos the other speakers are working. Normally they have a separate amplifier than that of the woofer. If you are comfortable working with a soldering iron and a multi tester, after unplugging from the mains, then you open the enclosure and check the continuity of woofer which should read between 4-8 ohms, if it is open or no reading, replace just 2 wires/terminals involve with 3 or 4 screws. If the woofer reads a continuity, then it is the amp which normally is just a single power IC attached to an aluminum heatsink. In some instances, it may be a power transistor pair. In any case you have to be familiar with component level repair. Otherwise, you are probably better off asking a qualified service personnel to do the repair job. Hope this be of some help. Pls post how things turn up. Regards.
Apr 26, 2007 | Harman Kardon HK595 Computer Speakers
ElectroVoice SxA180 Subwoofer Logo
836 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
