Question about Air Tools & Compressors
I want to run this compressor "RITIN RT2012" 2HP 12L (1.5kW) compressor. It's a 110V AC drive unit and I have 240V. Can I run it or do I need to convert the Power supply.
  • 54 Answers
You can't just run it on the 240 Volt supply. Check the motor nameplate. If it says it is rated for 110/220 or 115/230, or 120/240 Volts, then it is capable of running at 240V. This will require a wiring change, and you may need a larger size power cord.
The electrical diagram should be on the motor name plate or under the cover to the electrical terminals on the motor.
Posted on May 28, 2011
Package heat pump problem.
the gauge not changing and the pipes not sweating indicates the compressor is not pumping gas
I suggest that you call in an ac specialist to properly diagnose the problem and get a quote to repair
Aug 27, 2016 | Heating & Cooling
Rittal enclosure ac compressor no start but ac display A02 coming then power breaker trip how to troubleshooting
the failure to run the compressor then tripping a circuit breaker indicates either a failed start/run capacitor or a seized compressor motor
for this error ,it would be best if you got in an ac technician to properly diagnose the fault and get a quote
Aug 11, 2016 | Heating & Cooling
Unit stopped cooling, inside unit runs, outside unit does not
could be a gas leak ( low gas pressure shut off switch, failed start run capacitor for the compressor , vermin problem shorting out the power board outside
The inside unit is just a fan
call an accredited ac technician to get a proper diagnosis and quote
Aug 06, 2016 | Heating & Cooling
Compressor and blower of outside unt of AC are not working ....contactor in outside unit. latches for 1second and blower works for that 1second then off
power board or start/ run capacitor on outside unit
could be vermin problem across the board shorted it out
call a technician for a proper diagnosis and quote
Jul 13, 2016 | Heating & Cooling
I have a 6 yr old lennox merit 10acc system and the compressor doesn't seem to be running as there is no cold air and line out of compressor is not cold/sweating like my 2nd (good) unit.
you cant check capacitor with power on it nor using volt setting.need micro ferred setting on meter and check with power off and wires removed. leads go as follow for fan one lead on "C" and one on fan. For compressor one lead on Common and one on HERM. Also be sure voltage on capacitor is correct 360V or 440V. 440V will work for either. Also double check micro ferred requierment on motor and compressor. If its been replaced before may have been replaced with incorrect size. It happens.
Aug 23, 2012 | Heating & Cooling
My camper fridge , Engel SRBT-565D Does not run on 12V ?
The compressor is on the way out and exceeds the current capacity of the 12v inverter circuit. The compressor runs on 32V AC @50 Hz and the inverter circuit is not able to produce sufficient current when the compressor becomes worn. It still runs on 240V circuit as this is a straight step down transformer from 240 volts and is not current limited..
May 20, 2012 | Freezers
LP126HD3A rated for 265 volts AC single phase I have 240V ac single phase, how can I use this unit on 240V ac
You'd need to supply a "Buck-Boost" transformer to do this properly. Technically, the 265 VAC is one hot leg and neutral of a 480 VAC 3 Phase Y system that measures 277 VAC. The 265 number comes from this:
265 is the standard nameplate voltage for a 277 volt motor or AC unit.
230 is standard name plate for 240.
200 is standard name plate for 208
460 is standard name plate for 480.
110 is standard name plate for 120.
Most electricians call the hot leg / neutral circuit "277V AC".
Some popular "Buck-Boost" transformers will convert 208 to 240 and 240 to 208 volt systems, and 240 to 277 and 277 to 240 volt systems - among many other variations. These are auto-transformers as the primary secondary windings share a connection. KVA ratings differ significantly from name plate because of this fact. You should contact a qualified electrician to not only size, but wire the transformer for you. Failure to install a Buck-Boost transformer - and running this unit on 240V AC mains will cause premature failure of motors - fans and compressor due to overheating. This can also result in a fire hazard.
I hope this helps and good luck!
Sep 06, 2011 | LG LP126HD3A Air Conditioner
For the past two days I have had to reset the main circuit breaker for the outside unit. It appears to be running fine now. I'm just wondering is this an indication of the compressor about to go bad,...
Bill, first thing, make sure the outdoor coil isn't stopped up with dirt. This will cause the compressor to overheat and possibly trip the breaker. If you you can check the amp draw that would be good. Look on the data tag on the outside unit and look for RLA or "running load amps". Running amp draw should never exceed this number, it should actually normally run 10% under RLA. If its real hot where you are like it is here (109) it will be running close to RLA.
If you coil is stopped up with dirt, etc., turn off the breakers, use you water hose and sprayer and carefully wash out the coil.
If all this fails, and your amp draw is good, change your breakers. Hope this helps , stay cool.. Mark
Jul 10, 2011 | GE Heating & Cooling
Outside unit will not come on
Check the starter capacitor, and di you remember to add oil?
Aug 27, 2009 | Goodman CLQ36AR49 Air Conditioner
There is a squeal sound (high pitch) coming out of
The seal on the AC compressor has probably failed and allowed all the refrigerant and lubricant to be lost. This allows the bearing to run dry and now it is failing and making noise.
1. You could have the AC repaired, the compressor repaired or replaced and the system refilled.
2. You could have a mechanic disconnect the system and possibly remove the compressor (only if this model does not use a belt that relies on the compressor being in place).
3. It is probably way too late to try to refill the AC system with R134a refrigerant as it would just run out past the failed seals.
If anyone has an AC unit that just recently stopped making cold air they should attempt to recharge the unit (if it uses R134a - check your manual or underhood stickers). I just did and saved my compressor and AC unit from further damage.
Jun 17, 2009 | 1996 Jeep Grand Cherokee
Air Tools & Compressors Logo
166 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
