Question about Brinkmann 810-3250-G Grill
I have a brinkmann gas grill i just put new burners in it now i cant get but one burner lit at a time i light one and then light another and the first one goes out the flame is also very low??
  • jep246 May 26, 2011
    Thank you for the answer , will any grill regulater work my grill has 4 burnersw and a side burner plus a rotisserie burner
  • 252 Answers
Turn burner control knobs to "OFF", turn off the cylinder valve and disconnect regulator from LP gas
tank.Wait approximately two minutes.
2. Reattach regulator and slowly turn cylinder valve back on. The flow limiting device will now be reset.
If this does not work either one of the venturi valves is not connected properly or your will need to just replace the lp regulator if the above reset does not work please feel free to ask any ??
Also please rate me on my help thank
Posted on May 26, 2011
  • 675 Answers
There is a regulator that regulates the amount of fuel that comes from the cylinder...it sounds like the regulator may have become defective. the regulator is that round thing that is on the hose coming from the tank...they are readily available at most home improvement stores and most hardware stores
Some burners don't work
this is a gas fireplace & everything is on low flame high flame it just won't stay lit
Jul 01, 2012 | Brinkmann Charmglow Stainless Steel LP...
REPLACED OLD BURNERS WITH NEW GETTING POPPING OF GAS AND GOING OFF AND ON
you could try adjusting the air mix at the front of the burners seif that helps.
Apr 20, 2012 | Brinkmann Charmglow 810-7400-S Propane...
VERY LOW HEAT ONCE LIT. TAKES EXTREMELY LONG TIME TO COOK ANYTHING AND THE FOURTH BURNER DOES NOT LIGHT
The new propane bottles have a safety device in them that shuts down the gas if it senses the gas is going out the bottle too quick. Thank you Ralph Nader. To remedy this yall shut all valves off and remove the tank from the grill. Open and close all valves just for fun making sure all of them are off. Then reconnect the tank to the grill and SLOWLY open the triangle shaped valve to just bare ly open, maybe half a turn or less and then retry. More here
Jul 01, 2011 | Brinkmann Charmglow Stainless Steel LP...
How do I light the grill manually
Get a butane grill lighter. Open the hood of your grill. Remove the cooking grates and one by one turn the burner to low. Light the butane grill lighter prior to turning the burner on and as you turn the burner to low touch the flame of the lighter to the burner. Leave all burners on low, until you replace the cooking grates. Be very very careful, as you don't want gas to buildup before each burner is lit.
Then contact Brinkman for replacement ignitors.
Jan 30, 2011 | Brinkmann ProSeries 810-6330-W Grill
I have a full propane tank. I bbq'd about 3 weeks ago, same full bottle. Grill will not light. Good spark at ignitor. Used lighter and lit for a few seconds with low flame on high. No other burners will...
You may have turned the gas tank valve on too fast. Turn it back off, disconnect it and reconnect it. Then very slowly turn the valve back on. Light one burner at a time and turn to low before lighting the next. If you are hearing and smelling gas with the tank on but all grill knobs off, don't use the grill. You may have a leaking grill valve, regulator or hose. If you are only smelling gas with the knobs on, it's possible you have a clogged burner or orifice from bug nests, spiderwebs, etc and need to clean it out first. Hope this helps. Douglas
Jun 13, 2010 | Brinkmann Charmglow Stainless Steel LP...
Searing Unit Keeps Cutting Out After Release of Knob
First I have a couple of questions for your question on how to fix your Brinkmann Gas Grill, Model 810-8501-S
1). Did you push the igniter for 3-5 seconds after you turned on the Sear Burner (remember, this needs to be done AFTER you've turned the control knob to HIGH).
2). Once the burner is lit, you then need to continue to PUSH & HOLD the control knob for another 30 seconds as this somehow seals the deal, thus this should solve the problem.
3). However, if this does NOT work, you may have a defective Sear Burner and the best thing to do is to contact the Customer Service Department over at Brinkmann:
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free: (800) 468-5252
Local: (972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Hope this helps!
Apr 10, 2010 | Brinkmann Stainless Steel All-In-One Gas...
The burners decrease in strength when another one
If this is an LP grill, you can try replacing the regulator.
Dec 25, 2009 | Brinkmann Charmglow 810-7400-S Propane...
Grill wont stay lit
These new tanks have a safety device installed in them . If you open the valve quickly or tip the jug the damn thang won't work. Take the tank loose, open all the grill valves and close all valves. Reconnect the tank and SLOWLY open the valve a hair. Light the burners. No need to open the valve all the way. if you do the dumb safety will plug the jug.
May 08, 2009 | Brinkmann Charmglow 810-7600-S Grill
Brinkman 810-2400-0 grill
Brinkmann is an inferior product in my experience. Buy a new grill from someone else.
Jul 30, 2008 | Brinkmann 810-2300-B Grill
Brinkmann 810-3250-G Grill Logo
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
