Question about Dryers
Dryer on but no heat( avanti D110) - Dryers
    President:
  • 3,074 Answers
SAFETY FIRST UNPLUG DRYER......if its running then all thermos must be intact so it has to be two things: 1) the heating coil take the unit apart make sure the two heating points still have the cables attached and coils are intact, if they are 2) then find the thermal fuse and bypass it, take the two electrical connectors off the thermal fuse and tape them together( this is just to test, once done disconnect them as it is a safety feature and left bypass will cause a fire) if it heats then a new thermal fuse is in order>
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Posted on May 25, 2011
Electric cord overheated, blew fuse, need replacement
Contact Avanti Customer Service, or search for a replacement using eBay or Amazon.
May 11, 2015 | Avanti D110 Electric Portable Dryer
Heat is blowing out but the drum is not spining
You broughtke the belt of drum wont turn you might take the dryer apart to make sure the idler pulley is spinning free also. They sometimes get tight and burn the belt up.
Apr 10, 2015 | Avanti D110 Electric Portable Dryer
I have a Avanti dryer and after its on a few minutes it also cuts off. Can you tell me why or what to do to fix this problem?
see this causes and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and needs replacing. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub.Replace the Heating Elements
Oct 17, 2012 | Avanti D110 Electric Portable Dryer
What is the heat selector knob?
This allows you to adjust the temperature to match what you are drying. Some fabrics and clothes require low heat or you may only be drying a small amount of clothes and don't need much heat. You also may not want high heat to avoid shrinkage of some clothes.
Jul 16, 2012 | Avanti D110 Electric Portable Dryer
What material can I use to make a replacement lint filter for my Avanti D110 dryer? The original is about 9.5" round thin filter material that fits onto the screen lint filter. If I know what ...
Hi renfrorichte...
I would use fibreglass window screen cut to the size needed.
Bonded with a good glue such as 3M's Weather Proof Adhesive or Contact cement.
Please take time to rate me
Sep 05, 2011 | Avanti D110 Electric Portable Dryer
NOT HEATING
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 11, 2011 | Avanti D110 Electric Portable Dryer
Drum will not rotate
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2010 | Avanti D110 Electric Portable Dryer
Dryers Logo
119 people viewed this question
Top Dryers Experts
