Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
Belt came off of Maytag MVWC400VW1. The other day washer stopped after it filled with water. I emptied and noticed agitator was freely moving. I lifted up and looked under washer and belt was totally off but still seemed good. Not sure where, how to replace this belt. No diagrams or anything. Please help.
  • 185 Answers
SOURCE: Agitating
try a new timer
Posted on Mar 28, 2008
Jimster
  • 240 Answers
SOURCE: Maytag Mav2755AWW
I would imagine that this would be a top load washer is that correct? Yep sure is. I would imagine that the brake package on the bottom of the unit is probably faulty. It could be the stator, the brake pad, or possibly the snubber. The only problem is without a special tool, you wont be able to remove the stator (please do not try to remove without this tool, you can be seriously injured or killed for sure). Unplug the unit, then tilt it back against the wall. Place something under-neith to be sure it doesnt fall on you, then remove the belt off the pump/motor/main pulley. Twist the thrust pulley (center pulley at the trans) back and forth and see if you can hear the squeeking from down below. If you can hear it right there, it could be the brake/pulley/or snubber assm. Let me know what you find out, and if the squeeking is not coming from there, fill me in on if you can see or hear where its coming from. Thanks!!!! Jim
Posted on Jul 02, 2008
Lumpy816
  • 246 Answers
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Posted on Jul 09, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Posted on Feb 14, 2009
  • 84 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
I have a Maytag Atlantis MAV6200AWW Washer agitates and spins. Water sometimes empties. Pump is fine spins freely and the impeller is fine. Could it be the belt ?
You will need to check for an article of clothing stuck between the basket and tub that may be partially blocking the drain hole.
Nov 22, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer will not agitate
A Maytag A412 is well over 20 years old....
Best guess is a corroded upper drive shaft, the one that the agitator is mounted on. Certainly it can be called a transmission problem.
Jun 28, 2017 | Maytag Washing Machines
Kenmore Series 80 top loading washer that doesn't spin or agitate
Unplug machine, remove water pump and motor, behind the motor is a coupler, take broken parts to your local appliance parts store. Costs 16 bucks, replace the broken parts with new ones, reassemble machine. Never ever do a blanket/comforter in your machine again!!
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't spin
Could be a worn belt,
Empty the machine and tilt backwards, you may need some help to do this.
Remove the belt and check, some times these appear OK but may have stretched.
Chech the agitator pully, try to rotate, will only move in one direction, see agitator moving as you do, get the person helping you to see this.
Check the motor moves freely on the tensioner, motor will appear to move 2".
Fit a new belt and try.
Apr 16, 2008 | Maytag PAV2300 Top Load Washer
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
119 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
