Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Model 79576282600 kenmore elite bottom freezer top half not cooling
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
  • 2318 Answers
If this appliance is new, I would suggest to contact the vendor or manufacturer and ask them for in home service.
It could be the thermostat that might be not working properly or not set properly.
Check the user manual for more info on the thermostat settings.
Posted on Jul 08, 2008
  • 66 Answers
SOURCE: refrigerator not cooling
This could be that it is out of balance. Set the temperature settings to midway. This control can easily get the fridge temp out out of balance if over adjusted. If you already have the tmp control at midway then you need to make sure there are no obstructions to the duct that carries the cold air from the freezer to the fresh food section to cool it. Check for ice buildup or any kind of blockage. Let me know what you find.
Posted on Nov 16, 2008
  • 3600 Answers
SOURCE: kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Posted on Jun 18, 2009
  • 108 Answers
SOURCE: 1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Posted on Jul 26, 2009
Top not cold but bottom works fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Model 795 77304600 bottom freezer purchased dec 06
WHAT IS WRONG WITH YOUR FREEZER?
small_3_29.jpg For a detailed Freezer illustration, click below.
Chest
redarrow.gif Upright
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
It doesn't work at all
It's not cooling
It cools poorly or it's all iced up
It's noisy
It doesn't cycle off
Hope this may help you;
Regards,
VOTIT
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Bottom freezer works top isn't cooling and noisy
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Aug 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite refrigerator
It sounds like the fan is not circulating the air from the freezer to the fridge. Since it's new then you should contact the store where you purchased it for exchange or repair immediately.
Jul 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 75212 fridge doesnt cool off
Well there is a diffrence between no air flow and not cooling is the freezer working?? We can go from there
Sep 16, 2007 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
97 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
