Question about Hasbro Playskool Tonka Interactive Rumblin Chuck
I am trying to change the batteries and I can not find the battery compartment. I removed the two screws on the belly and I can not get it open so I do not believe that is the proper location. Please help. Thanks
  • 110 Answers
  • Lisa Fletcher
    Lisa Fletcher Dec 22, 2011
    Instructions for Chuck are actually here in .pdf format
    http://www.hasbro.com/common/documents/6...
Charger
The Furreal Butterscotch pony is operated by 6 D sized batteries.
To replace them open the velcro on her belly and loosen the screw holding the battery compartment. You can then replace the batteries and turn the pony on after repeating the procedure backwards.
Mar 27, 2014 | Hasbro Furreal Friends Butterscotch Pony
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | Aston Martin Vanquish Cars & Trucks
How do you get into the battery compartment to change the battery?
The battery compartment is located right behind the center console in the G-class. To access it you will need to remove the cupholder assembly. It should have only 2 screws holding it down. Once you remove those screws and move the cupholder to the side you should be able to lift up the carpet so that you can remove the battery cover. If you have any problems let me know and I will try to help in anyway I can.
Jan 25, 2011 | 2007 Mercedes-Benz G500
Need to replace internal clock battery
This may have been solved by now however...
REMOVE MAIN BATTERY... Before Opening any compartments!
The CMOS battery is located in the modem compartment.
Place the unit upside cown with the rear connectors facing towards you. It is the compartment on the right rear corner (i-screw to remove). It may be difficult ro open due to the modem labe sticking to the cover. Use care when attempting to pry door open.
Battery is CR1220 0.5in Diameter (Dime Size) (40mAh Rated).
Alan
Feb 22, 2010 | IBM ThinkPad 390X 2626 Notebook
Sio/Scan Temperature Transmitter 433MHz for batteries
I just changed the batteries yesterday. It was hard to open the battery compartment with bare hands/finders. I used flat screw driver to poke into the notch in the center of the transmitter. Or you can try poke into any **** around the compartment. It works!
Feb 17, 2010 | SkyScan 86709 Atomic Wall Clock
How do I change batteries on a cordless mouse MX5000. There is no door/cover to open.
Steps to change the mouse batteries:
1. With the small end of the mouse pointed towards you, just take your thumbs and slide the other end out.
Take note: The word logitech should be upside when you are doing this. It takes 2 AA batteries.
I hope that it is very helpful for you..Thanks..:-)
Nov 26, 2009 | Logitech Cordless Mouse
Change batteries in my wireless mouse
There should be a battery compartment on the bottom of your mouse. It might have a small screw holding it in place. Open & remove old battery, replace with fresh battery. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | Computers & Internet
Bonnet release
look at it,scratch bum and light a *** puff on same whilst you survey situation.Then go down cafe for coffee .come back and get a big screwdriver and grovel under engine compartment removing belly plate.Find the torch ??then do into town for new batterys and another coffee ,come back talk to another customer for half hour then lay under car and shine torch up and flick lever back so bonnet opens and remove the spanner you left under bonnet last time .Refit belly plate take car for a test drive and go to cafe again for a pincho of tortilla and another coffee.charge customer for a days work.
Jun 09, 2008 | 2003 Renault 181
Openning battery comparment
Underneath the mouse the little compartment that holds the usb stick can be removed to reveal the battery compartment.
Jan 23, 2008 | Microsoft Wireless Notebook Optical Mouse...
Hasbro Playskool Tonka Interactive Rumblin Chuck Logo
3,715 people viewed this question
Top Hasbro Toys Experts
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
