Question about Sony KDL60EX700 60 in. TV
Standby light blinking 7 times KDL60EX700 model number
I would like more info, such as what color the light is. Assuming the light is red, it means that service is required. It could be a number of things, but two of the more common include an electrical fault (such as a blown fuse or burned-out power supply)or a programming error (which I'd be leaning toward because of how new the television is).
There is good news and bad news: The bad news is that there is no way of knowing what is wrong until it is opened up and serviced. The good news is that it knows that something is wrong (as opposed to not working and not having a blinking light), so there is a good chance of a successful repair.
Also, the number of times it blinks unfortunately isn't indicative of a specific fault. It would be nice if it were that easy though.
Posted on May 25, 2011
  • 643 Answers
Have you replaced the lamp?? The lamp may need to be replaced. Hope this helps.
  • Greg Anderson
    Greg Anderson May 25, 2011
    This particular model is edge-lit LED. There isn't a lamp to replace.
  • Mando Mojica
    Mando Mojica May 25, 2011
    ooops sorry. unit then is still underwarranty if under a year old. 7 Blinks usually indicates a powersupply issue.
My sony tv shuts off after 30 sec or so and blinks 4 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 12, 2016 | Sony KDL60EX700 60 in. TV
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
What causes TV on powering up to go to standby and red standby light flashes 7 times every 2 seconds?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 12, 2015 | Sony KLV-40V300A 40" BRAVIA MultiSystem...
Tv won't turn on
High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. 7 blinks to standby light indicates this. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 21, 2013 | Televison & Video
-Check your Manual look for something called blinking codes should be around page 9.
-Please tell me you have a warranty, if not this can be expensive. Ranging from the main control board.
- Have you tried cleaning bot ends of your LVDS Cables, this can sometimes remedy the problem.
Aug 27, 2013 | Sony KDL60EX700 60 in. TV
My sony led tv model # kdl60ex700 blinks 6 times my sonny TV blink 6 times model # KDL-60EX700. What is wrong
I need more information like:
When it is turned on,
Turning off,
Connecting to something,
To close to the wall......Things like this to better you with your problem.
Aug 27, 2013 | Sony Grand WEGA KDF-55XS955 55" Rear...
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV will not come on.
The 7 blinks indicate a high voltage shutdown (high voltage exceeded 33,000V). This is usually caused by a defective regulator. Could you please post the exact model number (KVxxx) and I'll look up the part you will likely need?
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony KDL60EX700 60 in. TV Logo
509 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
