Question about Royal Sovereign ARP-1000EX Portable Air Conditioner
MY PORTABLE AIR CONDITIONER MAKES A LOT OF NOISE.
My portable air conditioner is making noises. What is causing it?
The condenser fan making contact with something or the bearing is failing
Oct 16, 2015 | LG LP0814WNR: 8,000 BTU PortabAir...
Unit will not get cold and makes a lot of noise
there must be filf in the sistem and the noise means that the compressor is overworking it self, i recomend u to turn on the unit and see if it smells strange ,if it does the commpressor is over heating and needs mantainance urgent
Sep 09, 2012 | Amcor PLM-14000E Portable Air Conditioner
Fan is making rubbing noise
Time to have an expert look at it as it might be a fan about to fail or something worse.
Aug 30, 2012 | Haier 8,000-BTU Commercial Cool Portable...
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
Make make a labor some noise at some time , compressor starts and
I have the same problem....throw this unit out and never buy Danby....shame on Danby for selling junk....
Jul 21, 2010 | Danby Portable Air Conditioner
Just brought home a fedders aep09d2b*b portable air conditioner. bought it used. it worked well there but when I plugged it in at home it is making a lot of fan noise - more noise the higher the fan...
If it was running fine before and you moved it and it's making noise, it sounds like something fell against the fan blades. The reason it sounds worse when you turn it up is that the fan is running fast. Grab a flashlight and check to see what might have fallen.
May 12, 2010 | Fedders A6P09D2B Portable Dual Hose Room...
Makes loud rattling noise and air conditioner quits blowing cold air
something is obsructing the fan. Unplug and Open the unit and try spinning the fan by hand. Remove any obstruction.
Jul 30, 2009 | Windchaser Portable Air Conditioner -...
New unit has loud noise & doesn't drain. Too late to return!
drain line kinked? trying to diagnose a noise problem over the inter net really hard . could be compressor
Jun 17, 2009 | Danby Portable Air Conditioner
Makes loud noise when first turned on
It may have been damaged in shipping or from the manufacturer. I would consider exchanging it for a new one.
Jun 15, 2008 | Danby Portable Air Conditioner
Royal Sovereign ARP-1000EX Portable Air Conditioner Logo
125 people viewed this question
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
