Question about Bang Olufsen Bang Olufsen BeoCom 2 24 GHz 2Line Cordless Phone
Hi B&O Beocom 2 - since moved house does not seem to work - when power on says no contact with base but then either asks to set date etc or just says line is busy - opened the PSTN base unit and power on to both phone base and pstn base
4 Suggested Answers
SOURCE: Problem with B&O beocom 6000 ''extension'' no contact with base
I think you just need to re-register the phone to the base. Press the button on the base station (between the 2 charger pins) then go to the handset setup menu, scroll to register handset.
Posted on Jun 17, 2009
pacman869
  • 4 Answers
SOURCE: My Beocom 6000 table base unit no longer charges
If your base has a charge indicator on it and it indicates that the handset is charging when the handset is in the cradle, I would say you need a new battery. RadioShack sells a replacement battery for $22.00 at the following link
http://www.radioshack.com/product/index.jsp?productId=2815547&CAWELAID=107599274
If the charge indicator doesn't come on it is unlikely that it is the battery. You may be able to get the phone repaired by the manufacturer but it may be better and more practical to get a new phone.
Posted on Jan 08, 2010
pctech1
  • 1940 Answers
SOURCE: Dear, I have a Beocom
BeoCom 5 - compatibility with Bang & Olufsen bases:
BeoLine 2 - Full function. One line only, if the handset is in a system which also includes BeoCom 6000 MKII or BeoCom 2 MKII handsets.
BeoLine - One line only. Limited functions.
BeoLine PSTN - One line only. Limited functions.
BeoLine 2 - compatibility with Bang & Olufsen handsets:
BeoCom 5 - Full function. One line only, if the handset is in a system which also includes BeoCom 6000 MKII or BeoCom 2 MKII handsets.
BeoCom 6000 MKI - One line only. Limited functions.
BeoCom 6000 MKII - One line only.
BeoCom 2 MKI - One line only. Limited functions.
BeoCom 2 MKII - One line only.
For the base and the handset to be able to communicate, the handset must be registered to a base. Up to eight handsets can be registered to the same base. You cannot register a handset to
more than one base. If you want to register more handsets to a base, and one or more of these handsets are BeoCom 6000 or BeoCom 2, the oldest handset model should be registered first. The functional operations will then be limited to match the operations of the oldest handset registered.
Disconnect the base from the mains for at least two seconds and then reconnect it. The indicator light flashes, and the base is open for registration for five minutes.
Try unregistering the Beo5 handset, and then registering the Beo2 handset first, followed by the Beo5 handset.
Posted on Jun 04, 2011
Had a att el52300 base that went bad so bought another one it seems to be working ok. all head sets have out of Range or no Power at base.Tried to clear with answer given but nothing worked Need help
Try the following:
1/ Make sure the power cord is securely plugged in at the base and that it's powered on ie: light is on and working etc..
2/ Reset the telephone base. Unplug the electrical power. Wait for
approximately 15 seconds, then plug it back in. Allow up to one minute for the cordless handset and telephone base to reset.
3/ Place the cordless handset in the telephone base for one minute to allow the cordless handset and base to synchronize.
Manual available here:
at&t el52300 manual
-Charles
Jul 02, 2016 | AT&T El52300 Cordless Phone
We have a Uniden DECT 6.0 series phone and voicemail service through AT&T. For some reason, the base answering system has been picking up calls, seemingly at random. Sometimes the base picks up, s
Hi Jessica,
I would suggest contacting Uniden rather than AT&T. I included their contact information below as well as 3 issues that may be going on here.
Uniden Technical Support
1.800.297.1023
M-F 8:30am-11:45pm CST & 2:30pm-4:45pm CST
Ask a Question: http://mycusthelp.net/UNIDEN/_cs/QuestionAsk.aspx?sSessionID=&
1. Are you getting messages? If not, the voicemail may have set to "Announce Only." This means the Answering system will answer the call, but will not allow callers to leave a message. If so, there may be an LED "A" lit up on your base. You can change this setting in the Answ setup --> record time.
2. Does it occur after a particular number of rings? You can set the voicemail to answer after 2, 4, or 6 rings. This may be the problem.
3. Does the phone ring at all? It is possible the phone is in Silent Mode. You can set silent mode to last anywhere between 1-9 hours or keep it on all the time. If it is set to a particular number of hours, the phone will exit silent mode automatically. If not, you need to hold # to deactivate it. I don't think you can set silent mode to turn on automatically on a schedule, but this is something you could ask Uniden about.
I hope that helps. Good Luck!
Jan 08, 2014 | Uniden D16602 Twin Cordless Phone
How to move my contacts to memory card
1.Go to contacts.
2.Select an contact.
3.There will be many option.Select "move to"
4.It will ask that that contact should move to Sim or Memory card.
5.Select what you want and enjoy.
Sep 29, 2013 | Nokia E71 Smartphone
BT Aura 1500 Quad telephone - calls list freezing
BT gave me solution, which (so far) seems to work:
Reset the software of the telephone to default settings...
On any handset - 1. Press 'menu' 2. Scroll to 'settings' & press 'ok' 3. Scroll to 'base' & press 'ok' 4. Scroll to 'reset base' & press 'ok' 5. 'System PIN' will be displayed - enter '0000' (unless you have altered the default pin number) 6. Press 'ok' 7. Press 'yes' 8. Switch the main base station off at the power & remove the batteries from all handsets for approximately 30 minutes .
This didn't reset my address book (thank goodness) but did reset some other settings, such as time/date, OGM, group ringtones etc.
Jan 15, 2013 | Lands Phones
Hi , i've HP ML370 G4 server , after power failure , the server can't boot . i try to reinstall memory & remove all parts & fix it agian but the problem still there , then after about 1 hours it's...
It may be that the lithium battery is dead; usually a CR2032 button battery. Signs of CMOS Battery Failure Dom Tech Computer Blog
Go into the BIOS settings during initial power on boot up, often F10 or F2 are common. Check the date and time, if they are off, you should be able to temporarily boot by setting the date and time but you'll have to do it every time you boot. If the date and time is off, and you set the correct date and time and it still doesn't boot, you'll want to make sure it's booting to the correct drive.
When it doesn't boot, does it give you any error?
Jul 04, 2017 | HP ProLiant ML370 G4 Server
Feb 25, 2009 | Lands Phones
Phones out of Range
If you start over and unplug the home base and then plug it back in and set the time and date etc, then re register all the handsets by placing them into the base for 10 seconds each, that should take care of the problem,,,Good Luck.
Jan 16, 2009 | Uniden 5.8GHz Dual Cordless Phone
Bang  Olufsen Bang Olufsen BeoCom 2 24 GHz 2Line Cordless Phone Logo
435 people viewed this question
Top Bang Olufsen Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Bang Olufsen Lands Phone Expert? Answer questions, earn points and help others
