Question about Norcent Technologies DC-1020 Digital Camera
Sd card not being read. I have tried two different 4gb SD cards. These cards have the smaller mico chip inside the SD card. I also tried to format the card with the camera but not able to do this either. I just bought the camera and have had it one day only. Jay
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Norcent Tech... Master
  • 102,366 Answers
The DC-1020 works with SD cards up to 2GB in size, not SDHC cards 4GB and larger. The same limitations apply to microSD and microSDHC cards used with adapters. The adapter will make a microSDHC card appear as an SDHC card to the camera.
You need to use SD or microSD cards, 2GB and smaller.
Posted on May 25, 2011
HOW do I format SD cards for Easyshare Z612? Can I use a "PNY 4GB SDHC card?"
You can Format by entering the camera's menu and find the format section. Click Here and see Pages 36-39 for detailed instructions on formatting your SD Card. Also your camera is not capable of reading the High Capacity SD cards (SDHC) so you will have to stick to the SD cards (2gb or smaller)
Jun 20, 2011 | Kodak EasyShare Z612 Digital Camera
I bought an sd micro chip for my jazz dv151 camcorder, but everytime i put the chp in it reads memory full. The chips work in anything else but wont work in the camcorder. How do I fix this?
Whats the size of your SD Micro chip? Is it 4GB or larger?
You probably bought a SD-HC chip (wich includes 4GB and larger chips). Any SD card that is bigger than 2GB is in this HC-format and will only work if the device supports it.
As you can see here in the description, your device does infact only support SD cards up to 2GB. http://www.amazon.com/Jazz-DV151-Digital-Video-Camera/dp/B001F7MXJS
I guess you will need to use smaller ones in order to make them work with your camcorder.
Best regards from Germany :)
May 02, 2011 | Video Cameras
I have 2 different sd cards 4gb that the card won't format or read because it won't format it.
The DX7630 works with MMC and SD cards. Your 4GB cards are actually SDHC cards, not SD cards. While they will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Jan 28, 2011 | Kodak EasyShare DX7630 Digital Camera
I am trying to format a 4GB SD card for my camera and it will not format
The DX7590 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to use SD cards 2GB and smaller.
Dec 09, 2010 | Kodak EasyShare DX7590 Digital Camera
How can you format a SD 4gb card for the Kodak EasyShare Z612 Digi Camera
You can't. The Z612 uses SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card and is incompatible with SD devices.
For SD cards (2GB and smaller), you'll find the Format operation in the Setup menu. Press the Menu button, then use up/down to select the wrench, then press OK.
May 13, 2010 | Kodak EasyShare Z612 Digital Camera
I have put a 4gig sd card in my finepix a900 and it keeps saying "card error"
Hello :
Look for a tiny switch on the side of the SD card . This switch indicated [ Lock or Unlock ] . You need to unlock it . If that didn't help , then you need to format the SD card before using it . If that didn't help also , then the problem is with your Camera and not with the SD card . there also must be a sensor in the [ reader on the camera ] which detects the position of the switch. Maybe there is dirt in the sensor. The best way to check would be to try another SD card . but you could try blowing out any possible dirt and see if that fixes the problem . If that didn't help , then you need to format your 4giga SD card before inserting it inside your Camera .
72b3844.jpg PLEASE DON'T FORGET TO RATE !
good luck .
Apr 08, 2010 | Fuji FinePix A820 Digital Camera
Got a new memory for my phone it is a nokia 6300 and the memory card is a 4gb sd micro card and it keeps saying card not formatted wot can i do to format it i have tried on the computer but it is still...
Most likely the phone that doesn't read it and the SD card reader can read "SD" cards but not the "SDHC" that a 4G card will be. All SD cards 4G and above are SDHC, and a plain SD card reader will not read this card.
Buy an SDHC reader, and get a smaller (up to 2G) card to use on the older phone that can't read the 4G one. Hope this helps.
Apr 07, 2010 | Nokia 6300 Cell Phone
My 4GB PNY Optima sd card will not read
Try the 4GB card in some other reader, or your camera, to confirm that it does work.
It's possible that your card-reader will not support anything over 2GB.
Dec 10, 2009 | PNY 4GB Secure Digital High Capacity...
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
SD Card Wont Work
Check if the SD card is iserted properly into the camera, eventually pull it out and push it back inside the camera. Also remove camera batteries , repeat the operation, and put back batteries.
If the card still does not work test the card into a different device, it is not unfrequent that an SD card comes defective from factory. In this case take the card back to the retailer and a have it changed.
If the card works on a different device, then it may be that the NV3 does not support 4 GB , there is no mention about max SD format supported in camera specs, or in the manual. In this case I suggest testing a 1 or 2 Gb card at the shop, and then buying right one.
Regards
Apr 02, 2008 | Samsung NV3 Digital Camera
Norcent Technologies DC-1020 Digital Camera Logo
175 people viewed this question
Top Norcent Technologies Cameras Experts
vwong
Level 1 Expert
mohamed salim shaikh
Mitch
Mitch
Are you a Norcent Technologies Camera Expert? Answer questions, earn points and help others
