How to change batteries for the retractable mouse
  • 27,725 Answers
The batteries in the mouse usually placed on the bottom of the mouse there is a plastic sticker rub your finger firmly over the top you should feel a small dent there will be a screw under it there should be a removable usb device located on the mouse remove it from the mouse and place it into a usb port your mouse should be ready to use
hope this helps
Posted on May 25, 2011
My retractable mini mouse is not working. I don't know how to open to change the batteries if that is the problems, help!!!
You are not giving much information as to the make and model of the mouse but since it is retractable I assume that refers to a cable. Wired mice do not have batteries, they draw their power over the wire from the USB port. If it is not working, try another port. Try the mouse on another computer or try another mouse on this computer to determine if the problem is the mouse or the computer.
Feb 07, 2017 | The Computers & Internet
How to change batteries to mini optical mouse
There are no batteries. It's a wired USB mouse.
Apr 26, 2014 | iHome Optical Mini Travel Mouse W...
Fix retractable mouse
if your mouse use batteries, clean contacts and replace batteries.
use the small switch for adjust.cleant the surface with some solvent from dirty.
If the mouse use USB, restore to system control in control panel, put the last date that you know was working Good.
God bless you
Jul 23, 2013 | Computers & Internet
HP retractable mouse in Acer notebook stopped working.
maybe your mouse has gone bad, i've had that happen before
Feb 15, 2012 | Acer Aspire One D255E13438 Netbook
My Targus optical mini-mouse with retractable cord just stopped working.There is no light underneath. Does it have a battery? Or is it just bust?
are your mouse is bluetooth or cable?
if its bluetooth, its definitely need a battery. if its cable then your mouse probably already damaged because there is no light from your mouse.
hope this useful, regard riyan
Mar 29, 2011 | Computers & Internet
My mouse isn't working. it is ge 98768 retractable mini mouse
hi
this is because of lose coonection in the wire. r the USB port got damaged. jus trying using another mouse if it works in your computer then the problem with the usb port.
Jul 05, 2010 | Jasco GE Notebook Mini Retractable Mouse -...
M trying to fix my retractable mouse. do you have any diagram showing how the insides of the retractable mechanism looks like. much thanks!
Optical mouse from inside: http://www.gadgetrivia.com/photos/o/56422-best_optical_mouse.jpg (this isn't a retractable mouse, but the inside looks exactly the same, only the cord this different which doesn't matter in this situation).
Here are instructions for optical mouse repair: http://www.thenetguruz.com/hardware/diy-optical-mouse-repair/
But if your mouse doesn't work first plug the mouse in the USB slot and check the laser beam under the mouse - if there is no light, the mouse is dead, and you should return it to the seller for replacement. (Such a thin cable of the mouse is very vulnerable and might break easily. More over I find many negative reviews about this rectractable mouse - so if your seller offers to replace it - ask for a different model or test it with your laptop right in the shop before bringing it home.)
2) Here is a solution that already worked for another user, but was very complicated: http://forums.toshiba.com/t5/Keyboards-Touchpads/USB-mouse-not-recognized-drivers-can-t-be-installed/m-p/23526
3) Or alternatively download and install a free driver updater software, e.g. http://www.innovative-sol.com/drivermax/index.htm - let it scan and update all your missing drivers - it may fix USB general problems if this causes also the mouse problems.
Apr 10, 2010 | Generic Memory Mini Retractable USB...
My Gigaware optical mouse's cursor won't move
Sounds like the laser failed. Return it for replacement.
Mar 16, 2010 | Ultra Max Gigaware Wireless Laser Mouse
NXTECH NOMR ( USB Retractable mouse) is not
Go to my computer proeprty then hardware then device manager.
Then uninstall all usb driver then restart your computer then check.
then if your usb mouse not works then check your usb ports works fine also try your mouse in another computer if it not works then you need to repair your mouse.
Aug 24, 2009 | Computers & Internet
Fades in and out
Sounds like the batteries are weak and need to be replaced. Hope this helps. Bud
Nov 27, 2007 | GE Optical 98802 Mouse
Open Questions:
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
