Question about Samson Audio Players & Recorders
I have a Samson S6 300 watt powered mixer. My "Mono" send jack is not functioning. I would like to know how to replace this female jack.
4 Suggested Answers
robotek
  • 1512 Answers
SOURCE: SETTING LEVELS ON MY POWER MIXER FOR MICING DRUM SET
Go check out these pictures, and there is some good info about micing up your drums. :) Recording it is then a case of getting levels good for a start by worling your way around the kit one drum at a time setting the level for that drum. a bit of nice reverb in the mix and out come you drums.... whoooohhooooo
Posted on May 13, 2008
heavyice
  • 374 Answers
SOURCE: echo into mixer
I think the Echo's output goes into the mixer's input.You should be using one's output into other's input...that's how things work.If you r talking about both the system's input then they won't work with each other. Other thing is that if it's mono then there r cable available for the use which transfers mono to stereo input and vice-versa.
Posted on Jun 07, 2009
  • 8 Answers
SOURCE: Connecting two powered mixers
Hi, If you have small electronics knowledge this might help you. First fine in each mixer the amplifiers line In if your mixer has two amplifiers then you have four line In. Disconnect this line from your mixer and build a circuit Line out multiflier. You can use op amp for this application this is a simple circuit. You made two input and four outputs. If you are interested i can send you a schematic diagram.
Posted on Aug 10, 2009
How do i connect a Behringer 1202 mixer to a Behringer B215D Powered speaker
Looks like both units accept 1/4" jack & I think the 1202 is unbalance out, so just use a standard screened mono (i.e. 2 pole "TS") jack to jack lead & you should be fine. Good Luck! :-)
Jul 28, 2014 | Behringer B215D Powered Speaker (550 Watts...
Having problems connecting speakers via a power amp in to my behringer x2222 usb mixing desk - im not getting the ins and outs correct :(
I had a like problem with a crown amp. I found it was in the amp settings , nothing to do with the mixer set up. We had it a mono setting. Take a look at your amp set up book, i'll almost bet thats where the problem is
Dec 06, 2012 | Behringer Xenyx X2222USB USB Audio Mixer
Power mixer to a power amp.
You have two aux sends on that mixer so quite easy to use one of those to feed the external power amp. You could have one set of spkrs connected to that amp and another connected to the powered mixer. This would give you full independent control over each set.
Aug 09, 2012 | Samson Xm910 8Channel Powered Mixer...
Txm20 samson ... unit wouldnt turn on... where is the fuse ?
if its not right next to where the AC power plugs in, or part of the power plug itself ( lil notch in cable recepticle that will allow it to slide out ) then it would have to be inside the mixer on the power pcb. ( the board the power cable connector is soldered to)
Aug 31, 2011 | Samson TXM20 20 Channel Powered Mixer,...
How do i hook up my mixer to a samson s.com plus compressor
Use INSERT cables to insert into the MAIN's. This will compress the whole level going to the mains.
Aug 04, 2011 | Samson TXM16 16 Channel Powered Mixer,...
Have a problem with the xp510i - left channel has no output to speaker. Tested with other speaker and cable - appears to be the mixer.
"Tested with other speaker and cable" ... you did not tell us the results of the test. If swapping the speakers and cablles still had the same dead side, it is probably the power amp for that side and not the mixer part. Take in for repair. If you had an accident of speaker cable not being plugged in fully or pulled out while operating, this pops the power amp real quick. They also just plain fail at times. Plug a set of headphones into the MONO out jack. If you can hear audio going through the unit then the mixer is OK... and the power amp on the failing side has a failure. Note the headphones will be low level and probably only one side, usually the left as this is a mono signal and headphones are normally stereo.
Apr 26, 2011 | Samson EXpedition 510i Speaker PA System
Hi, i have been suggested first a Samson servo 600, then a sx1200 is there a difference between the 2? is one better than the other?
the servo series is geared more towards studio applications and/or installs, while the sx series are geared for live pa applications. the servo 600 is 300 watts per channel @ 4 ohm, and the sx1200 is 450 watts per channel at 4 ohms. the sx amp can also be bridged over to mono mode, where it puts out, i think, 1100 watts mono.
the only variable i havent been able to cover is sound quality, and im not seeing those listings in the specs on the samson website
Jan 12, 2011 | Samson SX1200 Amplifier
I cant hook up mic and guitar same time
get a 1/8" stereo to mono splitter from radio shack or the like. it should have 1 1/8"male end, and two female ends, you could possibly get a 1/8" male with 2 1/4" female connectors, or use an all 1/4 inch adapter, with a 14/ to 1/8 adapter on the male end.
this should divide the guitar and vocals into left and right channels.
Feb 27, 2009 | Edirol UA-4FX External Sound System
267 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
PBandJ
PBandJ
Level 1 Expert
 Grubhead
Grubhead
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
