Question about Samsung HZ30W Digital Camera
My flash on my Samsung HZ30W, will not operate under any conditions. When the shutter button is depressed, the flash symbol in the image window turns red and just blinks.
  • 643 Answers
The lamp for the flash is burned out. Go to samsung.com they have a flat rate repair for all there cameras. Hope this helps.
Posted on May 25, 2011
When shutter depressed "AF" and "SB" LED's flash
My camera's shutter will not depress all the way due to a red flash light coming up all the time in the Flash-Ready indicator lamp (refer to pag 28 in the Nikon manual). It can be full sun outside but it will not work due to the red flash light coming on.
A work around is to select a flash mode of 'cancel'.
There is a button toward the front of your camera called the flash mode button. Click that until you see strike mark on the flash icon of your monitor screen (see page 32 in the Nikon manual).
The camera must have a malfunction of determining the lighting so it always thinks you need to have a flash on the picture. Of course this is not 'fixing' the flash/lighting issue but you can take typical day pictures for now with this work around.
Dec 17, 2008 | Nikon Coolpix 5400 Digital Camera
Nikon D70 Flashing
ERR is i think an error message generated when the camera can not read the cf card ? have you had an problems with corrupted images ?
Sep 24, 2008 | Nikon D70 Body Only Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Indoor flash images are blurry
It is possible you have the Flash Mode set to one of the Slow Sync modes (lighting bolt with the word Slow). Slow synchronization flash sets a slow shutter speed for the background exposure and fires the flash for the subject exposure. Since the shutter speed is slow, your subject should be still and the camera should be on a tripod otherwise blur can result. Since this mode should only be used when the above conditions can be met, you should use the FILL-IN FLASH (single lighting bolt symbol) mode for most situations that require a flash for correct exposure. Repeatedly pressing the FLASH MODE button will cycle through the various flash mode settings.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Flash images are blurry
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Images are blurry
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Samsung HZ30W Digital Camera Logo
269 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
