How much is 100x.62cents ? - Office Equipment & Supplies
  • 23 Answers
62 cents
Posted on May 25, 2011
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
Multiply 100 by .62 and get 62 cents.
If you mean 100 times 62 cents (the same as 100 times $.62), multiply 100 by 62 to get 6200 cents or $62.
Swingline 100X no power
Try the obvious - check your power point is workinh by plugging a table lamp or whatever. Test the table is electrically ok. If OK get in touch with Swingline Support
Apr 25, 2014 | Swingline 100X Drop-n-Go Personal Cross...
How do you find 9 is 15% of what number using a proportion with the fraction 15/100 and cross mutiply to slove it
Start with the statement of the problem: 9 is 15% of x, or 9/x = 15/100.
Multiply both sides by 100x:
9/x * 100x = 900 for the left side and 15/100 * 100x = 15x for the right side. This gives: 900 = 15x.
Divide both sides by 15:
900 / 15 = 60 for the left side and 15x / 15 = x for the right side. This gives: 60 = x. Hence the answer is 60.
Mar 01, 2014 | Office Equipment & Supplies
Need help with fx - 991 ms to solve f(x)=100x-64*x^2+48*x^3 for different value of x
I am not quite sure what you mean by ``solve f(x)=100x-64*x^2+48*x^3 for different value of x``. Do you want to find the roots of the cubic equation 0=100x-64*x^2+48*x^3 , or do you want to generate values of f(x) for different values of the variable x.
For the first case, use the SOLVE program,
for the second, use the TABLE computational mode: Press MODE and select TABLE, then enter the expression to the right of the equal sign. In TABLE, X is the default variable.
Apr 12, 2011 | Casio FX-115ES Scientific Calculator
Does ExtentNet 100x support Zebra printer language ZPL2?
It doesn't support it directly, but it shouldn't prevent it from working. However it might be sending extraneous PJL commands between print jobs (example @PJL -12345X) which could mess up a label. ZPL is basically ASCII, the ExtendNet shouldn't prevent ASCII delivery.
Feb 14, 2011 | Extended Systems ExtendNet 100X Print...
Unable to print Zebra labels on a Zebra 105 SL printer. Sending the label from an I-Series computer through the EntendNet 100x print server to the Zebra printer. Does ExtendNet 100x support Zebra ZPL2...
A print server should just be a 'through-put' device, and the codes should go fine. ZPL-ZPL2 codes are subequently sent as comms to the printer port. Are you using seria; or parallel input to printer?
Yo can capture the codes to a file, and review if they are correct. The file would have to be viewed in a hex editor.(write to a file through the driver)
I routinely use different mfg. of print servers for thispurpose if the printer does not have an internal ethernet port. The only problem I have run into is a problem in network where a slow download is enountered.
Feb 11, 2011 | Troy ExtendNet 100x Print Server
Mf 2 model - where do you put the cedar oil when using 100x magnifcation. i have read the manual and do not understand. i am a novice
The oil goes between the cover slip of the slide and the objective tip. It can also help to put some between the condenser lens and the bottom of the slide. Be careful when using oil, as when rotating to lower magnifications, it is very possible for the 40x to get oil on it. The 100x is sealed to protect it, but the 40x is not. If oil gets on the 40x, it can seep up inside and destroy the lens.
It is also a very good practice to clean both the 100x and 40x after each use. If the oil sits on even the sealed 100x objective for any long extent of time, it will start to break down the silicon seal, and you can potentially have the same problem as with the 40x, where the objective acts like a wick of a candle and sucks up the oil, thereby destroying the objective.
Jan 20, 2011 | Premiere Microscopes MF-02 Binocular...
I got a telescope: emerson 50x/100x and i cant see anything in it
My son just got one too, and you can look down the street to see trees just fine, but in the sky, you will likely only be able to see the moon. It is bright enough to be seen with the 100x lens.
Dec 26, 2010 | Emerson Fans Emerson Refractor Telescope
Hi i want vista sound.what can i do
The easiest way would be to search the internet for the make and model of your motherboard and say sound drivers.
Suppose the make and model of your motherboard is Gigabyte 100X, then search Google for "Gigabyte 100X audio driver" and then download and install the driver.
Oct 16, 2007 | Microsoft Windows Vista Ultimate Edition
42 people viewed this question
jasbo
jasbo
