Magnavox 15" LCD TV 15MF050V
Have you checked the sleep timer
Posted on May 25, 2011
  • digitaldump Jul 25, 2011
    To find out which tiny part needs to be replaced to fix a 15mf050v that shutsdow after while email m2repair@gmail.com
Magnavox 46" LCD TV shuts itself off after a random amount of time.
Is there a person in your environs who is mischievous or prone to malfeasance? Someone may be using a TV-B-Gone on you. Check this out:
https://cornfieldelectronics.com/tvbgone/tvbg.home.php
Apr 14, 2014 | Magnavox 46mf401b/f7 46 Hdtv, Lcd 1080p...
My 15" magnavox LCD tv turns off and on by itself. It also looses programed channels. can you help with a fix? thanks, Steve
very common in this unit you will see a bunch of puffed up can like caps on the mainboard the values are on the sides chenge them out and you will be fine
Nov 18, 2009 | SNK Magnavox 15MF227B 15 in. LCD TV
Magnavox 37MF331D/37 keep asking for software upgrade
Your set either has a bad SSB (small signal board) or needs a software upgrade. Try the upgrade first by going to http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=FLAT_TV_CA&sct=LCD_LARGE_30_40_SU&grp=TV_GR&session=20090830171041_4.131.87.247&ctn=37MF331D/37&mid=Link_Software&hlt=Link_Software
Download the latest software release for your set then follow install instructions that are contained in the user manual for your set.
Jul 22, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself
Mine was doing the same thing. Update the firmware and it fixes the problem. Updating the firmware is done by downloading the file to a thumb-drive from the phillips product support page then plugging in the drive into the side of your television and turning it on. See your manual for slightly better instructions.
Jul 08, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 15inch lcd shuts itself off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 15, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Magnavox 15" lcd says it has attention no signal
Had the same problem. The solution: My remote has a button labeled "TV/VIDEO". I must have accidentally pushed this button so when I turned the TV on it was searching for the signal from a VIDEO source. It couldn't find the signal so it's programmed to automatically turn off if no signal is received. All I did to solve problem was I turned TV on and before it could turn off by itself I pushed the "TV/VIDEO" button on my remote to switch it back to receiving TV signal.
Jul 13, 2008 | Philips Magnavox 27MS343S 27" TV
15MF050V/17 magnavox
Check the main power button on the back of the t.v
Jan 14, 2008 | Philips Magnavox 42MF521D/37 Television
Dropped Magnavox TV
Most likely the LCD panel itself had damaged.
Jan 01, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Magnavox lcd tv 15mf050v/17
I put heat-sinks on U14 and the regulator above it and the TV has been running fine all day. Always shut off after 14-30 minutes before. Heatsinks were just 1/2" x 1" metal strips with silicon thermal compound that I taped up to hold in place to temporarily test, as it is obviously a heat related problem.
If you try it and it works for you, post it here.
mwl777us@verizon.net
Dec 11, 2007 | Philips Magnavox 42MF521D/37 Television
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
