Question about IBM eserver xSeries 220 8646
I9990650 ac power be restored - IBM eserver xSeries 220 8646
GA1400A generator,engine running well, but no electric output! Can you help me please!
Probably has lost exciter current. It can be restored : take wires from a 12 volt battery, use something like 16 or 18 gauge, and with generator running insert bare ends into the AC outlet - one to neutral and one to hot (doesn't matter which is positive or negative). Insert and remove quickly. There should be a flash and current restored. If not, do it again until you get that flash. Once you have that, the exciter current is restored and you will now have power. The reason for the light gauge wires is if you are too slow to remove the wires and AC is restored while still connected to the battery, the wires themselves (or one of them) will burn out and protect the battery from AC current. So be careful! I assume all breakers on the unit are on?
Apr 10, 2014 | Electrical Supplies
Have a 4000 watt sportsman generator that will not produce electric i have replaced the avr what next
Could be lost exciter current. This is how to restore it - Connect 16 or 18 gauge wires to a 12 volt battery. With generator running, insert bare ends of wires into AC outlet - one to Hot, the other to Neutral. Insert and remove quickly. There should be a flash and power will be restored. If not, repeat until you get that flash and output current restored. Using light gauge wires is so that if you are too slow to remove them once AC is restored. they will burn out before the battery suffers from the AC incoming. Be quick and be careful.
Mar 31, 2014 | Buffalo Tools Sportsman Series 4000 Watt...
My power indicationlight is blinking thus the ac is not cooling
Could be some of the overload protection: low or high pressure,
Check for a clogged filter or dirity condensor or evaporator, condensor or evaporator fans not running.
Mar 20, 2014 | LG Heating & Cooling
1996 montecarlo ac has no power to it
There are two pressure switches installed in the tubing for the AC system . One stops the compressor when there isn't enough freon and the other one stops the clutch when the hi side pressure is dangerous. Put a can of freon in it without the engine running. That should be enough to restore power to the clutch.
Jun 29, 2013 | Honda Ac Compressor Cr-v 1998 98 1999 99...
How do I restore my Toshiba Satellite A30 303 back to factory settings.
press power on button and press F2 to enter BIOs
in last select restore to factory setting and save changes by click on link or press F10
Aug 20, 2011 | Toshiba Satellite A30-303...
When fixing the power cord socket on to the board it power the board but immediately I try to plug the auxllary onto the board to supply the processor it shut down the power.putting the two same time onto...
Motherboards can be configured to react to the application of AC power in several ways:
* always automatically start-up as soon as AC power is supplied;
* never automatically start-up when AC power is supplied;
* if on when the power stopped, come on;
if off when the power stopped, stay off.
Leave the auxiliary-connector NOT connected, if your computer works without it.
Enter BIOS SETUP, and change the 'POWER' settings, if you want the computer to stay "off" when AC power is restored.
Oct 22, 2010 | Biostar P4M900-M4 Motherboard
I need to perform a system restore to factory defaults but forgot to make a restore point when I bought my computer. I have an ASUS G73J and need to restore it to factory default without a windows 7 cd as...
Right after you press the start (power on) button for the notebook, tap the F9 key about once every second (do NOT hold the button down, as this will cause the machine to think there is a problem with the keyboard, and generate a 303 KEYBOARD ERRER) to take you into the system repair subroutine. There should be an option for "Factory Restore", however, you'll may need to dig a little to find it. Once you select the factory restore option and the process begins, DO NOT interrupt the restore process at ANY time!!! (also, be sure the notebook is plugged in to an AC outlet, as battery power may not be sufficient for this task, and the restore process goes fast on AC power anyway.
Sep 23, 2010 | ASUS G73JHA1 Notebook
The machine will not start up with what appears to be a fully charged battery and AC input
HI,
this can be either
no power/no post /no video situation
when you push in the power button do you see the power light on
if not follow the following
please follow these steps
1) take out the ac adapter
2) take out the battery and try to start the laptop with AC adapter in (on sate) see if it works
if upper solution works call the laptop manufacturer tech support either your motherboard or battery is faulty
if it doesn't start with solution above
1) take out both battery and ac adapter from your laptop
push and hold the power button down for 15 seconds and then put in the battery and try to start the laptop, (this step release any flee power in laptop)
if none of the above works you have to call your laptop company (this was for no power issue)
if you see upto the limit when windows logo appear then
restart the system again and then keep tapping the F8 key when the manufacturer logo appears
and you will be taken to a menu that says safe mode in one of the option, select safe mode and press enter
check if you are able to login into safe mode if so, that means you have a video driver issue
click start button > run > type in without quotes '%systemroot%\system32\restore\rstrui.exe'
> ok
you will be taken to a windows where you can restore your settings to a date when all was working fine, follow the instructions on the windows and select the date that was the one when system was working fine, > restore the system
(caution: when you restore a system back to a date any progarm installed after the that date will not work or appear in program menu as all the settings after that date is lost)
and when you will restart your issue will be hopefully resolved
if you are able to see the power LED its blinking or something
call your laptop manufacturer technical support
Further Queries are welcome
Feb 18, 2009 | Samsung X10 Notebook
IBM eserver xSeries 220 8646 Logo
1,220 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
