Question about John Deere Hood Gt242gt262gt275 Garden Tractors
I HAVE A jOHN dEERE GT 235 WITH A 42 ' MOWING
  • Roy Cagle
    Roy Cagle May 25, 2011
    Is there anywhere to insert bolts, nuts and washers or springs between the two to hold them together? You may have to drill them both out and insert fasteners into them to do so.
5 Suggested Answers
  • 221 Answers
SOURCE: Need mowing belt for 54" deck
It appears there are two belts for your mower. The primary belt is JD part M143019 and secondary is M118685. Your traction drive belt is p/n M127523.
The secondary belt for a 54 inch C deck is M154960 the other belts are the same as above.
I have used these folks for replacement belts before.
http://www.mfgsupply.com/MowerBeltsJD.html
I hope this helps.
Posted on Jun 29, 2010
wentlanv
  • 710 Answers
SOURCE: I was mowing in tall
Sounds like you're having a problem with your Power TakeOff system. The first thing to do is check to see if you didn't bump the PTO switch on your dash. Since you were in tall grass, check to see that there is nothing obstructing your machine.
If all appears OK, then the PTO should be tested. This is an electrical problem and requires a multimeter.
Before you test, check your battery to see if it's charged and that the terminals are clean.
For information on testing the PTO system, I'm pasting a web address with detailed instructions: >>>> http://www.ehow.com/how_7725472_troubleshoot-pto-system-john-deere.html
Copy and paste this link into your browser's address bar.
Good luck to you.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 16, 2011
  • 93 Answers
SOURCE: When mowing with my John
try sharpening the blades on the mower. dull blades can sometimes cause a strip of uncut grass
Posted on Aug 19, 2011
  • 640 Answers
SOURCE: My John deere LT 160
Check the blades, I expect that you will find that they are wearing out.
Posted on Aug 30, 2011
What size belt goes on john deere 214 deck
Go to Google type in John Deere lawn tractor model number then owners manual
Jul 08, 2017 | John Deere Garden
I was mowing in thick grass and my ride on mower stopped. If I try to restart I can hear and feel the motor trying but it just wont get going.
You probably hit something unseen. First check under you deck to be sure a stick or something isnt wedged in there. Check your belt and pulleys on top of the deck.
Im tempted to say check the flywheel key or adjust the valve lash.
Oct 25, 2012 | John Deere Garden
John deere riding mower will not go forwards or backwards and was just mowing yard with it. it will start it will cut grass but will not move now help
If it is the belt driven version you should have a deck belt and a drive belt. The drive belt is under the engine. If you have the hydraulic version check for a broken linkage at the pump.
Apr 22, 2012 | John Deere Garden
Have a Craftsman LT1000 and the discharge pipe on the grass collection tube continually gets clogged. The grass is not wet or overly thick and the blades are sharp. Engine RPS's good and i always cut...
Inspect the inside surface of the discharge tube. If you do not find any hangups, then I would wonder how fast you are mowing. If you are going full speed, I would recommend that you slow just a little. I was just thinking, have you been doing the same thing for a long time and recently have this problem develop. So, give good inspection. I do not know what type of bagger you have, but is the air able to escape the bagger, if it is not then it sets you up for a clog. If you can not find anything on detailed inspection of bagger system, there are sprays for under the deck of lawnmowers to minimize the chance of grass clinging to the underside of decks, you could try applying that to the ducting of your bagger. I hope this is helpful.
Aug 22, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
When mowing with my John Deere riding mower, it leaves a narrow strip of grass uncut in the center.
Aug 19, 2011 | John Deere 22HP VTwin 48" Riding Mower
Rider loses power after mowing for 30 - 45 minutes. Gets to a point, it won't climb a small incline. Engine sounds good & the deck runs fine. Just won't go.
Hi, the hydrostatic drive is most likely over heating. Remove the battery and battery carrier, from here you can clean all grass and debris from the hydro cooling fins and fan. Hope this helps, regards Phil.
Jun 01, 2011 | John Deere Garden
Need to know how to properly set the guide wheel heights on the mower deck and the blade height for proper mowing heights.
with a marker,mark on the front of the deck where the blade height is, and do the same on the back, do this so you can get your measuring tap in there.play with the adjustments till you get the front and the back the same height,it should be around 5 inches florida up north 3-4 inches. it is hard to find a mower that can be set for 5''. the shorter you cut the grass the more watering it requires. check your grass type and search it's cut height and food requirements for you area or growing zone, for a happy healthy lawn.. jay the pump repair guy in longwood Florida
May 26, 2011 | John Deere 26HP Hydrostatic 54" Riding...
John Deere Hood Gt242gt262gt275 Garden Tractors Logo
154 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
