Question about Vizio Televison & Video
My vizio flat screen tv developed a gray circle at the bottom of the screen and it won't disappear.
  • 13 Answers
SOURCE: subtitles disappear below bottom of screen
Check to see, what format the television set that widescreen etc. this may be all that's wrong with your set. If the problem persists the vertical height needs to be adjusted.  Most likely through the service menu, if units under warranty you can call Akai.  For further structures.
Posted on Oct 24, 2007
  • 6 Answers
SOURCE: Our Vizio flat-screen TV has developed a shadow in
look around the setings and you mite find something if not you need to by a new tv
Posted on Sep 06, 2009
djromann
  • 158 Answers
SOURCE: We have a Vizio LCD HDTV 47" Flat screen TV. We
You can try the special cleaning napkins for laptops, you can buy them in every electronics shop. Operate very softly avoid pressing on the TV surface. If even that doesn't help, well, it will remain like this, because of phisycally damage.
Posted on May 18, 2011
freetek
  • 5568 Answers
SOURCE: My vizio e420vl turned itself
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
Posted on May 29, 2011
  • 517 Answers
SOURCE: tv won't turn no the vizio logo only blinks
That problem is 2 causes,its either power supply or system board.
This are some D.I.Y procedure for troubleshooting.
  1. Open the back cover by removing all screws at the back.
  2. Try to look at the power supply board and find the leak/bulge on top capacitors.If you found,replace it with the same type and ratings.
  3. If the power supply doesn't have any leak capacitors.Try to power it ON to perform voltage checking.
  4. Check the output voltage of power supply such as 5vdc,12vdc and 24vdc by using voltmeter.If this 3 supplies having a voltage drop or flickering voltage while on power ON.Check the following parts on the power supply,change value/open resistor,shorted transistor and diode or repeat step # 2.
  5. When the output voltage is stable and all parts looks OK.The problem could be on system board.Unfortunately the system board or main board is not for D.I.Y because the parts inside is very logic and very sensitive.That is replaceable.
Thank you and good luck.
Posted on Jun 11, 2011
My Vizio developed a black circle in the bottom corner. Eventually, the black circle disappeared. Now when I turn it on these horizontal lines develop on the bottom of the screen. Any ideas?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 08, 2016 | Vizio Televison & Video
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Vizio tv screen went gray
Hi Mike,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 05, 2015 | Vizio E500i-A1 50" LED TV 1920x1080, 120...
Vizio tv dropped a channel, won't rescan
Try with the remote to direct enter the channel number (with the number buttons and or enter) If set makes it there go into menu for option to manually add it to the set memory.
Not likely a problem with your set.
Dec 17, 2012 | Vizio RazorLED M260VA 26" LED-LCD TV -...
My 22 inch Vizio flat screen TV won' turn on with
short of taking to a shop for an estimate most of these smaller screens get replaced versus repaired.
Aug 31, 2012 | Televison & Video
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 03, 2017 | Vizio VO320E LCD TV
Logos on the bottom of the screen won't disappear
that logo is CC close caption..to remove it go to the menu and find close caption option then select off then press enter..
Jan 02, 2012 | Samsung LN32A330 32 in. LCD TV
I think the inside panel is cracked
Yes lcd screen is cracked. No way to repair, other than changing screen. Cheaper to buy new tv.
Jul 20, 2009 | Vizio L32 32 in. LCD HDTV
Thin white static line at top of screen for some channels vizio 42 lcd hdtv
i had the same problem and it was fixed by enlarging the picture size or v-position. works great now.
Mar 13, 2009 | Vizio GV42L 42 in. LCD Television
Open Questions:
Televison & Video Logo
23 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
