Question about Ricoh Aficio 2228C Copier
In aficio 2228c the error code sc471...?? - Ricoh Aficio 2228C Copier
  • 57 Answers
The unit of the transfer belt is not installed properly
Sensor defective transfer belt
Problem of unity of the transfer belt
Posted on Jul 05, 2011
How do I locate a driver for a Ricoh Aficio 2228C?
http://support.ricoh.com/bb/html/dr_ut_e/re/model/c32_38/c32_38en.htm
Sep 22, 2014 | Computers & Internet
Error code sc393-01 functional problem within copier
Black TD sensor problem, check development unit connections
Feb 24, 2014 | Ricoh Aficio 2228C Copier
Question about my color copier
Replace the yellow drum unit..... Or have your service person come out and do a general cleaning on your copier.. Good Luck
May 06, 2013 | Ricoh Aficio 2228C Copier
What does trouble code "SC
Hello Ryan,
It means your device went thru a self check in an effort maintain optimum copy quality. Your device could not get Magenta (pink/red) to even get close to the target values for that color. The most likely cause (and we hope so) is the Magenta development unit is toast. Replace it. But of course there are a myriad of other fun causes. As a sidebar, you might want to consider replacing yellow and cyan at the same time as they tend to croak at pretty much the same time. You have a quite reliable device as a rule. It's worth the cost. Take care. Let fixya know I helped ya please. SPINAL
Jun 18, 2011 | Ricoh Aficio 2228C Copier
The copier is showing an SC623 code error.
Check that the cable unit duplex reversal is connected.
Replace the PSU if no power is supplied to the devices.
Replace the control front and back of the unit of inversion.
Jun 08, 2011 | Ricoh Aficio 2228C Copier
How to access sp5 on 2228c when changing developer unit
the only way I can help you is to give you a service manual.
The service manual is for 3800C but it`s the same machine.
You can download the manual by clicking HERE.
Jun 06, 2011 | Ricoh Aficio 2228C Copier
We have an Aficio 2238C that is giving an error message upon startup. It says functional problem, turn off unit and turn back on, etc.... error number SC471.\r\nI have tried the "yellow...
Probably this happened after a paper jam??? Yes???
This error is related to the Tranasfer Unit.
This SC 471 can be cleared by removing and re-installing teh Transfer Unit.
If this doent work you probably have to replace a mylar. For that i advise you to call a technician
Apr 07, 2011 | Ricoh Aficio 2228C Copier
How do I replace a drum on a ricoh aficio 2228C
It very easy...:) if you have a drum in hand.
Open the front cover. Lift one big green handle. Untainted 2 big black screws and open the drum cover. There you will see four groups of drum+development unit. Pull out the needed drum and pull in the new one. Then close all covers and that's all
pifonski
Mar 01, 2011 | Ricoh Aficio 2228C Copier
Error code SC471
SC471 is a Transfer Belt HP error. The transfer belt does not lift in the rear. The rear cam (G060 3894) slips past its locking tab on the square stepped shaft and slips off the side.
The fix: reposition the rear transfer belt lift cam to lock the tab into the square shaft. Secure the locking tab with a tie wrap.
Now this is the solution if you know what you are doing on this printer. I can not even begin to tell you in this forum how to dis-assemble the printer to get the transfer belt unit out and effect this repair. IKON is pretty pricy on labor. I would see if there is an independant guy locally that can do it. Inexpensive repair that I would charge $90 or less for. If you HAVE to call IKON then just make sure they do not try to tell you that you have to replace the transfer belt unit. This repair is all that is needed 90% of the time.
Good Luck and Thank You for using Fixya.
May 05, 2010 | Ricoh Aficio CL3500N Laser Printer
Printer was off for two weeks and now error sc471
SC471 means: Belt tension unit cam error. Even though the belt tension unit tires to return to its home position several times, the home position sensor is not activated.
Possible Causes:
Defective transfer belt unit.
Defective transfer belt tension unit.
CN25 Pin 3 on the engine board is unable to send a signal.
Suggested fixes:
Replace the transfer belt unit.
Replace the engine control board.
Replace the transfer belt tension unit.
I would start by opening it up and inspecting the transfer belt and associated parts. Pull them out and re-seat them. Look for broken wires, stripped gears, gunk in the works. Clean it, then put it back together and test.
If you aren't up to it, it is probably time to call the repair man.
Dec 16, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio 2228C Copier Logo
449 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
