I want to upgrade the ram from 1G to 2G --- I have purchased the appropriate upgrade chip --- but don't know how to access the board to install the upgrade --- I have removed all 7 screws from the back but can't seem to remove the back --- any ideas.
  • 2,632 Answers
Welcome to Fixya. To be able to help you out on your problem can you provide the make and the model of the computer so that we cab provide you the solution on how to change the Ram.
Thanks
Posted on May 25, 2011
INSTALLED NEW RAM UPGRADE TO BOOST FROM 1G TO 2G COMPUTER DOES NOT RECOGNIZE NEW RAM STILL SHOWS 1G.
Make sure it is the correct ram for your computer. If you just added one ram chip then try swapping them and make sure they have a tight fit.
To test the new chip replace the old one with it and turn on your machine. If it doesn't see it then it is either bad or not the correct one.
Let me know how it goes.
Dec 14, 2010 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
I upgraded my memory RAM 2g and added 1g so it makes a 3G of ram but how come when my pc boot up up i can only see 2G ram single chanel. wen i go to my my computer----properties----general under computer:...
Could you please go online and in a search engine type "MAX RAM E-Machines (here put your model #)." Pick a link that secribes your maxi,um ram and if it's only 2GB you'll have your answer. If the max is higher there should be instructions on how to set the computer to acess and show the RAM.
Regards,
Selk
Nov 19, 2010 | E-Machines eMachines Desktop PC
Ram Installation more than 3G ex: (4G or 5G) will read 3.25 G How? i am using 2 units of KVR800D2N6/2G pulse 1G original>
Probably your Operating System is a 32bit. 32bit OS can only read up to 3GB of RAM regardless of the capacity of RAM you install. For example you installed 2pcs of 2GB RAM, that makes it 4GB in total, 32bit OS will only recognize 3GB. upgrade your OS to a 64bit OS and you can upgrade your RAM up to 8GB depending on how much your motherboard can handle.
Sep 15, 2010 | Computers & Internet
MX3230 won't start after installing 1G RAM upgrade. Black screen. Nothing. Ideas?
Hi, i think the 1G RAM upgrade you did is not compatible with your laptop, try remove and uninstall it and get an appropriate grade that will go and work with your laptop.
Compliments and wish you best luck.
Dec 25, 2009 | Computers & Internet
Ram upgrade problems
looks like you have the wrong ram for your system Kingston is showing this for your system KVR667D2S5/2G
but try refreshing your bios i doubt it will work but give it a shot with your ram installed just hit F2 to get into bios when starting your computer save and exit that should refresh it
Nov 03, 2009 | ASUS Eee PC 900HD Netbook
Acer Extensa 5620Z will not work with more than 2GB RAM??
parrotheadpc is incorrect in stating "you can only have a total of 2048 mb installed".
the 5620Z accepts 2 x 2 GB SODIMM RAM, the machine boots and shows the full 4 GB in the BIOS.
the full 4 GB works with the Ubuntu x64 installer.
Windows XP x32 goes BSOD on startup.
Windows 7 x64 install from DVD fails with same BSOD error.
conclusion: this is a Windows-Extensa 5620Z incompatibility that would require a fix by ACER at the BIOS level.
question: there may be specific memory modules 2 x 2 GB which do work--anyone have it work with Windows?
Oct 02, 2009 | Acer Extensa 5620 Notebook PC
My computer will not boot up when 2 g ram
Try upgrading your Bios first, also make sure that the memory that you ar putting in your Laptop is type PC-2700. Other than this, I know that this comptuer has a 2G limit and should have no problem with it.
Sep 06, 2009 | Compaq Presario R3000 Notebook
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Feb 26, 2009 | PC Chips P23G Motherboard
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
Adding RAM
If it has 4 slots and supports 2Gb max with 2 slots currently populated with 2 x 256mb chips you'll need to remove both those chips and install 4 x 512mb chips to reach the max of 2 Gb.
May 10, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
