Question about Coleman Sport & Outdoor - Others
We crashed our 1990 coleman ram X 17' canoe and the front metal end peice broke. I need to find a replacement part. HELP
2 Suggested Answers
savindude
  • 175 Answers
SOURCE: I need a repair/owner's manual for 1999 Coleman
Tried googling Coleman? They might be able to help.
Posted on Jul 02, 2009
What year did coleman manufacture ram-x 15 - serial number 5905c700
That's not a complete HIN. IT should be 12 (or 13) characters.
Jul 08, 2014 | Boating
I have a really old coleman canoe & the front seat support bars are broken.Any ideas how to repair or where to find replacement parts? Coleman says its discontinued so no parts from them.
Compare with a Pelican canoe, and see if its parts will fit.
Alternatively, make something similar out of aluminum tubing or hardwood.
Do consider if the boat is actually worth fixing. A used Coleman can be found for $250-350, and if you do much canoeing a used (better canoe) can be found for $450-550 in most areas.
Jun 05, 2014 | Coleman Boating
Skid plate for coleman conoe
Try any canoe / kayak store and ask for skid plates. These are usually at least $20 to buy the plates alone, plus the stuff to install them. Adds 1.5 to 3 pounds. For a Coleman, which is very flexible, you might have to install carefully and with flexible adhesives rather than epoxy. Think about whether you really want to do it.
Cost for a shop to do it is probably $100 or so, and a worn Coleman is not worth that.
Apr 30, 2014 | Coleman Cable Boating
I have a coleman canoe about 1978ish model 5907-719 17 ft. I can't find a replacement center thwart. Any ideas?
Post a picture of what it looks like, if you can.
If it was wood, then just make one. Else make a wooden one to fit where the Aluminum would have been. That is the usual thing to do with older boats, and cost-effective.
If you really care about the canoe, seek out an old one for sale "well used" and buy it as a replacement or for parts. An elderly Colman is not worth a lot, so don;t spend a ton on fixing the first one.
May 24, 2013 | Coleman Boating
Colman Canoe Bracing Gone Loosing Shape
Your going to have to replace the bracing, the poly plastic your canoe is made of needs it to retain it's shape. If its an older one the bracing should be made of aluminum tubing, you can buy this then cut to size shape and fit to your canoe. If its a newer one say made by pelican {they took over for coleman} its made of plastic this will prove to be harder to do. Either way its a big job
Nov 08, 2009 | Boating
Water damage in ceiling, plywood warped, contact paper bubbling u
Seal roof seams. set up camper . prop peice of plywood slightly bigger than damaged area under damageshim to acheive moderate pressure. wait a week & remove. If it comes back down will have to replace paneling.
Jul 25, 2009 | Coleman Campers Grill
Jun 29, 2009 | Sport & Outdoor - Others
Canoe has damage on the front bow.
Bondo would probably work.
Also, you could laminate a few pieces of something like vinyl siding/facia board over the hole. If the canoe is ABS, the vinyl siding cold be "welded" / fused to the ABS with PVC primer & solvent/cement.
May 27, 2009 | Coleman Cable Coleman Inflatable Boat...
1990 Chevy CK1500 2 wheel drive pickup - Rear end
Is the rearend blown into peices? if yes replace the whole thing. If not put it in reverse and have someone look to see if the rear driveshaft is spinning. If it is you more than likely need a ring and pinion set in the rearend. If it doesn't spin the problem is in your transmission not the rearend.
Mar 15, 2009 | 1991 Chevrolet C1500
Need replacement glass for pilot cover of Coleman Presidential II
the glass is there as a service tool to veiw pilot and flame or relite just get a peice of sheet metal and cover hole with it ,it will work short term or long term
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Sport & Outdoor - Others Logo
73 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
