Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
We own a dream maker Spa and have noticed a leak when the pump is running. We've been told by a repairman that the bottom needs to be cut out and the insulation removed in order to find the leak. Does this sound reasonable?
  • 310 Answers
If it is only leaking when the pump is running, the problem is usually the shaft seal on the circulation or jet pump. This should be easy to check.
Posted on May 26, 2011
6 month old jacuzzi hot tub has started leaking intermittently , any help here to solve this problem
remove front panel visually inspect pumps to see if leaking if ok check by control box remove cover inspect where plumbing runs through keep eliminating thing until you find it
Sep 02, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
My dream maker leaks but im not sure how to obtain access to pumbing
That is not easy. Since there is no access but right at the pump area only. sometimes there is a bigger access from the bottom.
Oct 16, 2013 | Dream Maker Spas Pool & Spa
Just purchased a used Dream Maker X400 hot tub. It holds the water during the filtration cycles but if we attempt to use the hot tub by turning on the jets there is a major leak. Is this from one of the...
Have you opened the equipment access door and looked in it while it is running. I would look at the pumps to see if one of the seals are leaking. They will leak more on high speed and if you have a cir pump that runs the filter and an additional pump for high speed jet action it would make sense why it is leaking more while you are using it.
Oct 03, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas leak
This means one of your top jets is leaking. Firstly try Fix A Leak this will stop any leak up to an 1/8". If this does not help there will be more difficult work in store.
Each jet sits in a jet body, these jet bodies are behind the tubs shell, you'll need to get in behind them to see which one is leaking. This can be difficult as they are often covered in insulation foam.
Sep 05, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a dreamaker 8003 xspa that has worked perfectly over the many years that I have had it. The other day I noticed that the water had lowered 6 inches overnight an the water was coming out of the
1. Check equipment like pump, heater, blower, light fixture, for leaks.
2. Remove side panels closest to the are the leak is showing and inspect jets, plumbing in that area for leaks. If insulation is foam, remove any water saturated foam and follow it to the source of leak.
3. If the leak is in plumbing and is very slow, sometimes it can be resolved with "stop leak" products.
Aug 07, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hello, I own a Dream Maker Eclipse 4-person Portable Spa. We have it on the porch, and we have noticed a leakage apparently between the pump and the filter. Do you have any suggestions how to fix the...
The Dream Maker Company (Dream Maker Spas, LLC) will be your best bet at finding a local service center in your area.
Email Customer Service @ lisav@dreammakerspas.com. You will normally receive a response in 24 hours. Be detailed about your location (City, State, Zip) and try to provide as much detail about your spa as possible.
Dec 08, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
What size shaft seal is in a dream maker eclipse spa? I need a new one to replace my leaking seal.
Your spa should have the aquaflo pump which uses a PS-200 seal.moz-screenshot-1.png
http://www.ussealmfg.com/pdfs/ChooseThe%20RightSeal.pdf
Oct 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
793 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
