The source won't clear on the screen and stays visible while watching
  • 643 Answers
On the remote you should have a button labeled display. Hope this helps.
Posted on May 25, 2011
My sylvania 7" mini tablet won't start up. It only
It may need to be connected to a power source if this is the first tym u have turned it on.
Feb 24, 2013 | Computers & Internet
How do you clear codes for 2004 saturn ion
Clear the codes AFTER a repair was made & the light
stayed on ?
I would purchase an inexpensive $60.00 code reader &
use that.
If you start disconnecting batteries on every vehicle you
do or will own,then bad things happen.
The radio won't work,the car won't start,etc
If you have service manuals to learn your vehicles systems,
then you can eventually know what the results will be
Again,if you fixed nothing,then the light is going to stay on
or come back
Sep 18, 2012 | 2002 Dodge Dakota Club Cab
My BPL TV has Start-up focus Problem (BPL LCR 20)
change crt baise socket , it will clear your problem
Aug 23, 2012 | Televison & Video
Replacement water filter won't stay in place.
I too had this problem...the metal tabs in the filter housing need to be bent in toward the center to hold the new filter tighter...I also filed the tabs that rest on the spings down a bit to lessen the tension. So far so good!
Aug 01, 2012 | Frigidaire PureSource2 Water Filter WF2CB
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
When I turn my tv on, the picture and sound will be clear for about 2 or 3 seconds, then the screen will go black, but the sound is still clear. The screen stays black for about 5 or 6 seconds and the...
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both. In your case, it could be either.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
Jul 27, 2011 | Samsung LA40A450 40 in. LCD TV
I have an Akai PDP5016H television recently it will not power on , I have to push power button several times before it comes on , no picture and no sound , Occasional lly it will stay on with the AKAI ...
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced, and in your case you may need to look very closely. Caps that go in these situations are often grouped in pairs or fours.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
Jun 04, 2011 | Samsung Televison & Video
I have a Nixon LowDown Tide Watch and the screen is staying blank, almost as though it is in a battery saver mode unitl i press any button and its display turns on for 3 seconds or so then goes back to...
Hey, this just happened to my nixon watch (I have the nixon housing - same setup as the lowdown) and what you have to do is simply hold in the light display button for about 3 seconds and the display won't disappear after the light times out.
hope this helps :)
Apr 09, 2011 | Nixon Lodown Tide watch
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
