Question about Zyxel ZyWALL 5 UTM - Security appliance - EN, Fast EN with 1 year AV+IDP Silver iCard, CF Silver iCa... (ZYWALL5UTMKITCF) Firewall
The throughput of the Zywall dramatically decreases when IDP and AV are enabled. Is this a configuration issue? I do have the turbo card installed.
2 Suggested Answers
  • 87 Answers
SOURCE: I lost the password, and
you need to use the reset button on the back of the device: it is quite small, so you need to use a needle or a small sharp object to press it. You can find it under the label "Reset" on the back of your router.
Hope it helped,
Franz
Posted on Mar 01, 2011
Zywall l2tp ipsec
There are many root causes can make the VPN connection not stable. You should try to rule out the possibility that the outdated firmware cause the issue first. Contact zyxel tech support after you update the firmware.
Feb 19, 2014 | Zyxel ZYWALL USG 50 SEC-GTW 5 VPN TUNNEL -...
Hi all. I received a JUNIPER NS-IDP-200 (NSIDP200)
you can do it by just reseting the device using pin hole back in the device.
Sep 16, 2013 | Juniper Networks JUNIPER NS-IDP-200...
I lost the password, and i can not access the zywall 10. How can i reset the zywall to the default configuration?
Hope it helped,
Franz
Mar 01, 2011 | Zyxel ZyWALL 10 Router
My dad is death and I don't now the password ov ZyWALL 2 plus..please help me... im ITALIAN
Hello there,
Im sorry for your father, by the way if you forget / lost your password(cannot access the web configurator you will need to reload the factory-default configuration file or use the RESET button on the back of the ZyWALL. Uploading this configuration file replaces the current configuration file with the factory-dafault configuration file. This means that you will lose all configurations that you had previously and the speed of the console port will be reset to the default of 9600bps with 8 data bit, no parity, one stop bit and flow control set to none. The password will be reset to 1234, also.
The procedure to use the reset button
Make sure the SYS LED is on ( not blinking) before you begin this procedure.
  1. Press the RESET button for 10 seconds, and then release it. The ZyWALL restarts with the defaults restored. Otherwise, go to step2.
  2. Turn the ZyWALL off.
  3. While pressing the RESET button, turn the ZyWALL on.
  4. Continue to hold the RESET button. The ZyWALL restarts with defaults restored.
  5. Release the RESET button and wait for the ZyWALL to finish restarting.
Hope it help and have a nice day,
regards
Apr 15, 2010 | Zyxel Zywall 2 PLUS (ZYWALL2PLUS) Firewall
Can't install netgear router WGR614 IN AN DELL INSPIRON1594 LAPTOP
The laptop/computer's wireless card may not have the latest wireless card driver installed or it is not enabled and working. Check Device Manager to see if is is working and enabled. I suggest you install the latest wireless card driver.
Next check the wireless card configuration, it needs to have the wireless router's settings, ie SSID and encryption etc.
For instructions on securing and configuring the wireless router and wireless card please click in this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 23, 2009 | NetGear WGR614 Wireless Router
I have zyxel zywal 35 have two wan port, wan1 connected to t1 line, wan2 connected broadband line , now the firewall configured on active/ passive mode,it was working fine but some times. fire wall lan ip...
This is due to some bad packets on your network. Check the network for any worms/spywares. Also check if the ethernet connections/card donot malfunction.
Jun 19, 2009 | Zyxel ZYWALL 35 Firewall
Port 80 forwarding
use hidemyass.com as a home page surth from hear
Jan 24, 2009 | Zyxel ZyWALL 2 Firewall
Routing problem
I don't know if this will help because I don't see what you and seeing but here is an idea: In every routing scenario I have experienced, you must specify a default gateway with a specific IP address. 0.0.0.0 only points to the device itself, not the other WANS. The gateway IP addresses should be statically assigned. If there is DHCP involved, insure that the gateway address is not part of the DHCP scope but in an excluded range of reserved addresses. For SMTP to work the gateways (and you should have 2 or 3) must be properly configured and TCP port 25 enabled.
Dec 09, 2006 | Zyxel ZYWALL 35 Firewall
What do I do if the Throughput is not 108Mbps?
1. In the routers web-interface, click on login (password would be either blank or smcadmin) -> home network settings -> wireless -> channel and SSID. 2. In channel and SSID go to wireless mode and select the option 'dynamic turbo' and apply the settings. 3. Now turbo cards can connect at 108 mbps with turbo router in the wireless computer.
Feb 19, 2006 | SMC Barricade 7004 Router
Zyxel ZyWALL 5 UTM - Security appliance - EN, Fast EN with 1 year AV+IDP Silver iCard, CF Silver iCa... (ZYWALL5UTMKITCF) Firewall Logo
54 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
