Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP 7410 All-in-One
My HP 7410 demands a new 96 cartridge, but when I insert the cartridge refuses to recognize it. Tech support at the HP repair station said there is a design flaw caused by the metal arm that punctures the board the printer rests on so the recognition software fails to work. There is a replacement board listed in HP Parts, but HP refuses to supply this replacement part to HP repair stations. Any ideas where I can fix this problem?
  • 2 more comments
  • Anonymous Aug 29, 2008
    Printer
    I have the same issue with the printer not recognizing cartridge after new install.I found the spring had come off and punched a hole in the circuit board. I now need to locate a new board to repair it or I have a $400.00 paperweight in my office.
  • vondollens Oct 08, 2008
    Does anyone have any directoin on how to repair the curcuit wire/puncture or know of anywhere to buy the replacement part? I have 2 7410's that both have had the ink cartridge ribbon punctured.
  • wdp8 Oct 16, 2008
    error message is remove and check color cartridge and reinstall
    Sergeant:
  • 115 Answers
Just call and ask resolution for your query. Our aim is to provide full satisfaction to our users in easy way. For more information, click on http://resolit.us/HP-Support.html
Posted on Aug 03, 2017
HP made me "upgrade" to an L7780 refurbished printer for $349. Guess I got the wrong tech support.
Posted on Sep 25, 2008
Just chatted with online support. They agreed to replace the unit with no hassle.
HP will give you a new printer for free. I just did this through online tech support tonite. My unit is 18 months old. When you use the online tech support, save time and use this link that they gave me after 45 minutes of explaining my problem. http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01189384
Posted on Sep 24, 2008
SOURCE:
Print cartridge in right stall not supported for hp 2410
Print cartridge is a knock off. Cartridges have printed circuits in them that the printer can recognize as being the original replacement. This is to keep people from using other products in their printer, which I think is foul, since you paid for the printer and it technically belongs to you. Sometime HP will make cartridges with faulty circuits that the printer will not recognize.. If that is the case call them and demand a new ink cartridge.
Dec 12, 2017 | HP PhotoSmart C4180 All-in-One Color...
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 printer displays error ''remove and check colour cartridge
I think that spring must have gotten loose that holds the cartridge in place, right hand side, put it back where it belongs, might want to compare with the other, black cartridge side.  Good Luck!
May 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Printer does not recognize color cartridge for my HP OfficeJet 7410
its a broken spring clip on the side of the ink cartridge.
fixes are here;
http://www.fixyourownprinter.com/forums/inkjet/46650#83
and here;
http://www.fixyourownprinter.com/forums/inkjet/50913#243
hp is supposed to give you a brand new printer for free.
Apr 13, 2009 | HP LaserJet 8150 Printer
Are you sure it's a genuine HP cartridge? Sometimes remanufactured cartridges aren't recognized by the printers. HP and others make them so that they have a chip inside that ensures only new genuine cartridges can be used. Try a new HP and see if that solves the problem. If you've already tried that one, then make sure the contacts in the printer are clean. If you still have a problem, then I'd say try a new printer!
Oct 19, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hp 2610xi not recognizing HP 97 color cartridge
If you look in the 96 (Black) cartridge loading area you might see that the retention spring has poked a hole in the circut board. I am now either trying to replace the ink cartridge holder or purchace a new printer. I have about $70.00 in new ink that I can't use now. The 2610xi worked great until the spring popped out of its holder.
Jun 10, 2008 | HP Photosmart 2610xi All-In-One InkJet...
HP OFFICEJET 7410 ALL-IN ONE PRINTER GIVES MESSAGE TO REMOVE/CHECK CARTRIDGE ON RIGHT EVEN AFTER NEW HP 96 BLACK AND HP 97 TRICOLOR CARTRIDGES INSTALLED.
Were you sure to (1) remove the blue tape over the contacts, and (2) not to touch said contacts? You can try cleaning them with a lint free cloth and distilled water or isopropyl alcohol.
Jan 23, 2008 | Computers & Internet
Remove and check colour cartridge HP 23, HpPSC500 error
Did you trying cleaning the cartridge contacts on your machine?
Jun 23, 2007 | HP PSC 500 All-In-One Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
220 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
