Question about Namco Guncon 2 Gun for PlayStation 2
What is the small plug for. - Namco Guncon 2 Gun for PlayStation 2
  • 51 Answers
When playing time crysis, you can use two guns. the plug is where you plug in another gun.
Posted on May 25, 2011
How do I get the small plug removed from my Aberdeen Stainless Moen #7590SL so I can tighten the handle?
See this website (pdf) for you faucet. The plug you describe should just pry out using a small screwdriver. Plug the drains in the sink(s) before you remove the plug just in case you drop it.....:)
http://www.moen.com/shared/docs/exploded-parts-views/7590pt.pdf
Jul 05, 2017 | Plumbing
REMOVE A PLUG-IN ON 2000 EXTERRA ALTERNATOR
push down on center locking tab with small flat blade screw driver and gently remove plug
Sep 19, 2012 | Cars & Trucks
Cannot take dualit plug apart
Remove the small silver Dualit sticker from the pin side of the plug. There is a small screw inside that will undo the plug :)
Apr 04, 2012 | Kitchen Appliances - Others
How do i locate the spark plugs on a 2004 E 150? 4.6l v8?
Follow the plug wires from the distributer to the spark plugs. VERY tight on vans, typically takes several tools to get them all. Be very careful not to crack new plugs on install... Need to be a small person, with small hands to do this job...
Aug 21, 2010 | 2003 Ford E150
How do I set the fusing unit correctly?
How to fix the Error: "Set the Fusing Unit correctly"
Ricoh Aficio SP C411DN & C410DN Color Laser Printers
Instructions:
1. There is a short Wire Jumper (color: black or white) on the inside of the main electrical connector of the Fuser Unit.
Note: These procedures can be done without removing the outer plastic housing of the Fuser Unit.
2. Press the side clip (or tab) and first pull the tab end of the large connector plug from the main housing of the Fuser Unit.
Warning: The connector plug wires are very short -- it extends a maximum of about 1 inch (or 2 cm) from the main housing of the Fuser Unit.
3. Use a small screwdriver and gently remove the small white connector that the Wire Jumper is plugged into.
Warning: Try to remember the correct orientation that this small connector is plug-in.
4. Use a small screwdriver (or a small flat blade) and gently raise the small tabs on the front of the small connector, while pulling gently on each end of the Wire Jumper.
Warning: Do not remove Wire Jumper forcefully by pulling.
5. Make sure that this Wire Jumper is plugged into the same pins as the one on the old Fuser Unit that is being replaced. There are only three pins that the jumper can plug into.
6. Reassembly the Fuser Unit by plugging in the two connector that were removed.
7. Replace the Fuser Unit into the Ricoh printer and secure properly.
8. Power on the printer -- it should start-up and go to the ready state without any errors.
9. The END.
Apr 26, 2010 | Ricoh 4506 Copier
Just will not start
You have most likely done this but lets go back to the basics.
Do you have spark at the plug?
Check to see if the plug is fouled - pull the plug connect to the plug wire- ground the metal part of the plug to the metal body of the engine - as you turn the engine over it should fire cleanly from the center to the electrode, if it fires off to the side or has an orange colored spark it is fouled - replace it.
Once we have spark check for gas is it getting to the carb?
90+ % of all small engines not running are due to the fuel line or in tank screen being plugged with garbage. Remove the fuel line from the carb, point it down and using a small container to catch the gas it should flow freely.
If you have good gas flow reconnect the fuel line to the carb and put about 1 CC of gas in the plug hole reinstall the plug and fire it - almost all small engines use a bit of vacuum to pull the fuel from the carb into the cylinder, jump starting them with a very small amount of gas directly in to the cylinder can help them get going.
A VERY SMALL AMOUNT OF GAS AND CLEAN UP ANY SPILLS BEFORE YOU TRY TO START !!
Burning down the house will upset the other half
Mar 08, 2010 | Briggs & Stratton Garden
Cannot hear the ring in my awh75n headset.
There should be a small wire with a 90 degree plug on one end and the other will have a small ropund piece. The plug plugs into the headset base. The round piece has sticky tape on it and plugs on the speaker beneath the handset.
Dec 16, 2009 | Avaya AWH75N Wireless Headset
My power cord fell off. Took off the back of the
there is a small board with a small transformer . the plug is located next to that small transformer. if the cord originally came from the right hand side if you are looking at tv from the back. the plug is on that right board. if the tv cord came from the left side, the plug is located on the main board in the front of tv. the plug in both situations are the same, it is white in color and has 2 or three pins sticking straight up.
Nov 15, 2009 | Sony KV-32FS13 TV
Getting error: set fusing unit correctly on Ricoh Aficio SP C410DN. Have just changed thermister in fusing unit.
Take the unit out and install it again, making sure it is in all the way and sitting correctly. Then reset the machine and see if the error goes away.
Nov 10, 2009 | Ricoh Aficio SP C410DN Laser Printer
I need to put in some transmission fluid but i dont know where it goes????
there is either a really small dipstick that you can only get to from underneath or it has a plug inside the drain plug its like a bolt inside a bolt, if its the second one you have to start the car let it warm up pull the small plug out of the big plug and find a way to push trans fluid into the spall plug until it overfills then let the excess run out and insert small plug before turning the car off. kinda like a differential. but do not pull the big plug out or you will loose all the fluid
Sep 09, 2009 | 2002 Ford Explorer
Namco Guncon 2 Gun for PlayStation 2 Logo
193 people viewed this question
Top Namco Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
EnergeeUK
Level 1 Expert
Are you a Namco Video Game Console and Game Expert? Answer questions, earn points and help others
