Question about Technics Audio Players & Recorders
I have a Technics SL-QL1 direct drive turntable that works perfectly for about 5 seconds, then it suddenly repeats itself over and over... the record never advances beyond that point. It happens with any record that I have tried so I know it is not the record. I'm guessing its an issue with the direct drive, so could this be an easy fix? Or should I just forget about it?
I do not have an answer as I am searching for an address myself. The solution to your problem is probably in replacing the small belt in the turntable cover. This belt decouples the arm mechanism from its dedicated motor. The motor and the belt are located in the left side of the cover.
Posted on May 01, 2013
  • Technics Master
  • 5,487 Answers
I don't think it's the direct drive as that just makes the platter spin around. Since the stylus sits in a record which moves it forward, if it gets stuck then it's going to be something to do with the arm of the record player that can't move beyond that point. Check around the piviot of the arm for problems and look at the anti-skating control. If you can move the platter by hand that will prove it's not the drive if the stylus gets stuck.
Posted on Jun 19, 2011
How do I get the Autocue function to work on the Technics SL-D202 direct drive turntable?
When you say that the auto cue does not function properly,do you mean that the arm will not lift from the rest onto the record or do you mean that the set down point of the arm on the record is not correct? Or does it not work at all?
Jun 29, 2014 | Technics Audio Players & Recorders
Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
Sep 07, 2009 | Technics SL-1210 Turntable
Technics SL-Q200 Quartz Direct Drive
Your best bet is to get a good quality switch contact cleaner to clean all the contacts on the speed control switches.
I guess the contacts inside the switches will have corroded slightly with your turntable having been stored in the garage.
May 13, 2009 | Technics SL-1210MK3 Turntable
High pitched singing
It could be the wrong drive belt if the turntable is of the old fashioned type and does'nt have the direct drive. If the 33/45 switch isn't working properly then its a possibility its the drive belt tension on the turntable.
Apr 11, 2009 | Technics SL-BD22 Turntable
EVERYTIME I PLAY A RECORD IT DRAGS TO PICK UP SPEED
Are you sure you have a Technics SL1200MK2 Direct Drive Turntable? If so, then there is a major problem with the drive system. This can only be diagnosed and repaired by a qualified technician.
If your turntable is not the Techics SL1200MK2, and you have no idea what turntable you have, look at the model's label, if it says BELT DRIVE - this is the reason why it drags to pick up speed. If it says DIRECT DRIVE, then take it to a service center for repair.
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 02, 2009 | Technics SL-1200MK2 Turntable
Technics SL 1600Mk2 turntable works, but turns off seconds later
The SL1600MK2 is a direct drive turntable. Meaning that there are multiple electronic components which make it turn. With that said, the only place you can start is the main circuit board. Unfortunately, this will not be an easy diagnosis without the proper testing tools - multimeter, and a scope to get you started.
Otherwise, you'll have to take it to a service technican for repair.
Unfortunately, all parts for this model are discontinued, so if it's something that is specific to this unit, it will be very hard to source parts.
- OPTiC
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Feb 28, 2009 | Technics SL-1200MK2 Turntable
Techics sl-1210s m3 turntable spins back on itself
You have a fault on the quartz-lock speed control electronics. It may be a simple fix, it may be not.
It will require specialist investigation. A Technics dealer should be able to advise you, and arrange shipping back to Technics for repair if you decide that is the best thing to do.
Jan 15, 2009 | Technics SL-1210M5G Turntable
289 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
