Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
The diverter is broken , how to change it - Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
I have a 7950 Bissell. I can't get it to **** up from either the tools or floor area. I tried adjusting the knob on side but still no luck. Any suggesions?
First check to see if there is suction at the motor duct. If not contact you local BISSELL Authorized Service Center at http://www.bissell.com/customer-support/.
If there is suction,
a) Check if the small rounded window tabs on the Floor Nozzle are locked in
their mating slots and not inadvertently lifting the tank up out of place?
b) Check to ensure oval seal is in place at the top of floor nozzle window.
c) Check the diverter knob for proper setting and the diverter door opens and
closes properly. If no, and it does not appear to be broken, remove the floor nozzle window, open diverter door manually, keeping the flat
side of the door against the unit. Set the diverter knob on the tools setting.
Manually close diverter door until there is resistance, hold it in place while
turning the diverter knob towards the floor setting to lock it back in place.
Reinstall the floor nozzle window. (If diverter door will not lock back in place,
go to a BISSELL Authorized Service Center).
d) Check for the black foam gasket under the diverter door. Replace if
necessary.
e) Check floor nozzle window to ensure it is screwed down properly. If there is
a ΒΌ" gap between the window, where it wraps around to the side of the
unit, and the base on the slanted section, reinstall window.
This gap can be eliminated by installing the tabs at the top of the window,
hold it in place, then push up from the bottom of the window to bow the
window, push it against the unit and then evenly slide it down into place.
f) Check half moon window to ensure it is screwed down properly on
CleanView models. The floor nozzle window should be lower to the floor
then the half moon window.
g) Make sure tank is not full on the outside of the bladder.
h) Check the tank lint screen for debris. Remove it to check.
i) Check tank lid and tank for damage.
j) Check float and baffle to ensure they are properly installed properly. The
baffle should be even with the top of the tank
May 29, 2011 | Bissell 7920 ProHeat Pro-Tech Upright...
Need Diverter Door for Bissell ProHeat 8910
HI there SmartAlec from NelsonVacuums.com.au here. I am an australian service agent for bissell. If you go to my website and use the link to put in a request I can get the parts for any Australian bissell machine. Your question doent give your location so i am not sure if this is a help or not.
Regards Alec
HAPPY VACUUMING :)
Feb 20, 2010 | Bissell 8910 ProHeat Clear View Upright...
I have low suction and there are no clogs. What is the valve you suggested. # 53 pic is to small to see
There is a valve in you lower hose assembly and chances are its broken. It is supposed to stay closed when upright and open when tilted. When this breaks it opens slightly or all the way and is diverting suction where you don't want it.
Dec 07, 2008 | Hoover U5753-900 WindTunnel Bagless...
Flap
Most likely the diverter valve is broken part #2136988. You will have to remove the top to replace it.
Aug 04, 2008 | Bissell 1699 ProHeat Clear View Upright...
Replace the switch that controls hand tools to the upright unit
If that flap isn't moving when you turn the knob for floor or hose, then yes it is broken, part #2136988 is the diverter valve. You will have to remove the top cover, it mounts on the underside of it.
Jul 23, 2008 | Bissell 1699 ProHeat Clear View Upright...
Diverter knob & flap & gasket broke
You will have to pull the top cover off, it fits underneath unto the knob. When you see the bottom, you should be able to tell. The arm of the diverter goes thru the hole and then hooks onto the bottom of the knob.
Jul 21, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Proheat Clearview water problem
The water comes out the hose at the same time. The diverter only diverts the suction from floor to attachment. If it is constantly spraying there is a problem with the attachment. Is it not spraying on the floor?
May 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissel Proheat 7901 Diverter Knob and Flap problem--Helpppp!
Manual here in case you missed the link; http://www.bissell.com/images/UserGuides/7920.pdf Waiting on your photo as discussed. :)
Mar 14, 2007 | Bissell 1699 ProHeat Clear View Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
