Question about Linksys Wireless-G Broadband Router
Im trying to log on typing in the ip address to get to the wizard and i type in admin and it doesn't work? I'm trying to make my connection secure.
  • 4,350 Answers
Did you try 192.168.1.1 ?
Wireless Router settings:
It is usually easiest to run the install wizard, which you can get from the manufacturers' website, usually for free, but be sure to be ready to set the items listed below:
To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your Internet Browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit. Look under support, downloads, drivers or similar sounding areas.
Things to set:
(Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes. SAVE OFTEN.)
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is typically NOT the security issue.
2. Set a recognizable system ID (descriptive name is easier to find when you need to connect wirelessly).
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
5. Change the channel of the wireless to 11, and avoid conflict with landline cordless phones. (Big issue, even the neighbors can interrupt).
There are more secure settings available, all the way down to only allowing certain MAC addresses to have access. A MAC address is a digit unique to each and every network card. Like a fingerprint. Most users do not set mac address limits.
Posted on May 25, 2011
How to log in
Hello, I'm not sure which type of wireless router that is but most router to log in have the same user and password for default.
User: admin
PW: admin
But first, you must be connected to the router via Wi-Fi or by LAN cable.
Follow these steps:
1. Make sure that you are connected to the router.
2. Find out what is your gateway, this is the IP address from the router. You can google by your router model or check the instructions, also most router have the IP address in the bottom of the router.
3. Open a web browser and type the router's IP address, click enter.
4. If everything is correct, a new window should be display prompting to input the user name and password, remember to try admin.
If admin doesn't work, then try:
User: root
PW: 1234
Hope this solve your problem. Good day.
Mar 11, 2014 | TP-LINK TL-WN821N (TPLINKWN821N) 802.11b...
Where to find the wpa2 number
Have you tried looking on your modem?
Dec 02, 2011 | NetGear Computers & Internet
I just received a new modem from my cable company and now my router doesn't work. I tried resetting it and it still doesn't work. What do I do next
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a trendnet tew-625brp, i just opened it, i can connect to it perfectly by cable howeve i want to set it up wirelessly, when i go to 192.168.10.1, i type in admin for username and password, and it...
You must complete the setup with a wired connection. Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Sep 07, 2011 | Computers & Internet
Can't figure out the ssid number on my router
Just log into your router if you need to know it's IP address. Go to the command prompt type ipconfig /all then look for the Gateway IP address input that into your web browser and then hit enter. Go to the Network Settings page and you will see you SSID and password.
If you can't remember your password reset your router back to it's factory settings by holding the reset button for about 5 seconds. For your model/brand of router the default IP address is 192.168.2.1 The default password is "admin" Once you are connected to your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be your phone number for example 3109876543.
Sep 07, 2011 | Microsoft Broadband Networking MN-500...
My internet Connects perfectly to the computer to the modem.. but when I put my router inbetween the two, it stops working and i've tried everything including restore factory settings, and it still...
Well in order to access internet via your router, it needs to be configured as you said its being restored to factory defaults. Also always mention your ISP (Internet service provider), Router model no and Computer type with running Operating system for exact steps to fix such problems
Alright, first of all we need to establish physical connection with the Modem -> Router->Computer, then we will setup router
  1. Connect Ethernet cable from Modem to the WAN port of the router.
  2. Connect another Ethernet cable from Router LAN port to computer LAN port.
  3. Power cycle all the devices (Turn on Modem first, then Router and at last computer).
  4. Usually in case of Cable ISP, router would automatically get connection from Modem and Internet should start working.
  5. Else you can open Router admin page to configure
  6. You need to find the IP address of your router (usually Default IP of Netgear routers is 192.168.1.1). I can't tell what is the IP for your router as you didn't mentioned Model no.
  7. Open Command prompt (Start-Run-CMD) and type IPCONFIG.
  8. Default gateway address is the IP address of your router. (You can also find router's default IP on the its panel below.)
  9. Now next step is to access router interface.
  10. Open Browser and type http://192.168.1.1 (It is just an example, you need to use the IP address of your router, we are assuming its 192.168.1.1). Press Enter
  11. Type "admin" in usename and "password" in password box to login (both are in lower case without quotes)
  12. In the left side you can find Setup Wizard, Click on Yes and then Next
  13. Wait for the process to complete and then hit "Apply".
Ask me any questions if you need any help. Hope this helps.
Jul 13, 2011 | NetGear Computers & Internet
I need a zonet default IP to access the routes sharing so I can make my NAT type open for my xbox live instead of moderate or strict. could you please tell me the default IP address and also the...
Hello aclark447, I believe that the default IP address is "192.168.1.1", however if for some reason that doesn't work try running your command prompt (Windows key + r, type in cmd), and typing in IPCONFIG. If you are connected to it, it should be the default gateway. The default username and password for your device is user:guest - pw:guest. Hopefully this will fix your problem, please have a great weekend!
May 14, 2011 | Zonet ZSR1134WE Wireless Router
Connected to d-link network which is unsecured. how to secure?
You need to setup a password for the wireless connection,
1. Connect D-link Router to your computer
Your computer should be connected to the LAN port of using an Ethernet cable.Power on the router after connecting the router to your computer.
2. Log on to D-link Wireless Router
To logon to wireless router type the default IP address of the router on the address bar. The default IP address of the D-Link router is 192.168.0.1
Before log on to the router it will ask you the user name and password. For a default D-link router
User Name : admin
Password :admin(Flip the router over to know the default username and password)
3. Click on Setup Wizard
To configure the router in an easy way click on the button Setup Wizard.
4. Click on Launch Internet Connection Setup Wizard
To configure the internet connection in this D-link router, click on the button Launch Internet Connection Setup Wizard.
holygrass_21.jpg Now the wizard will show you what steps it is going to complete while running the wizard. Click Next to continue.
holygrass_22.jpg 5. Create new Password For your router
holygrass_23.jpg Setup wizard will prompt you to create a new password for your WBR-2310 Wireless Router. After entering the password click on next.
6. Select your Time Zone
Now the setup wizard will prompt you to select your time zone.
holygrass_24.jpgPost .
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | D-Link Computers & Internet
Cannot install D-Link router
1. check your wireless adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
Hope this will help
Nov 24, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
