Question about Dimplex Compact Electric Flame Stove Heater
Have a melted plug on my heating stove . what causes that and what can I do
    Brigadier General:
  • 4,736 Answers
Be glad you caught that in time. The overheat or overload sensor for your electric stove-heater has failed and needs to be replaced. If it is still under warranty, Dimplex will repair or replace it at no cost. Even if it's not still under warranty, Dimplex Technical Service wants to know about this. If you live in the USA or Canada, you may call them at 888-346-7539. If you live in the UK call 0845 600 5111 and ask for Technical Service. Either Dimplex USA or Dimplex UK, can provide the part if necessary.
Do Not use your stove-heater until this is repaired.
Hope this helped you. Please let me know.
Posted on May 25, 2011
Heard a loud pop that tripped the stove breaker and main breaker. Now oven wont work on bake or broil but all other functions work fine
Mike - this is for a stove / range - not a washer - right??
I suspect that one of the heating coils melted and shorted, causing the breaker to trip. Given that the main also tripped, it may be even more involved. Please provide more details - including the make and model of the appliance when asking for more help.
Dec 02, 2014 | Washing Machines
Why does the terminal block keep melting on my kenmore range left front burner.
Brother Jeff, this happens all the time because the connections are not perfect, causing arcing at the point around the connection. This arcing makes for excessive heat and melts the block. I replaced the connections on my Mothers stove top with crimped connectors and it lasted a lot longer. They didn't burn out any more, she just needs a new stove. So your best bet is to use crimp on connectors instead of the OEM block that's melting from a loos connection.
Dec 01, 2014 | Kenmore Kitchen Ranges
We have a JennAire model CP220W-C01 cooktop. We use the old coil type heating elements. There was a flash and smoke from the right front element. A repairperson replaced the connector, only to have it blow...
Unplug the element from the receptacle and then disconnect the receptacle from the point where it plugs into the stove. Now, carefully, turn on power to this heating element. If nothing happens then you have removed the likelihood of a problem in the large portion of the stove's wiring. Next, plug the receptacle cable back into the stove without connecting the heating element. Again, carefully turn on the power to the heating element in question. If there is no spark then the cable, connector and receptacle are ok. If it does spark, replace the receptacle and cable assembly. No spark, then inspect the heating element where it connects to the receptacle. Look for melting or signs of damaged insulation that would allow for a "dead short". If you see damage to the element then replace the element. No damage, clean the connections with a toothbrush, and plug the element back in and turn on the juice. If it sparks again, replace the element. Good luck and be careful. Don't attempt any of this if you are inexperienced in working with electricity. 220 Volts can cause death or serious injury... just the flash from an arc can cause blindness and burns.
Nov 05, 2013 | Jenn-Air Cooktops
Prestige induction
There may be an electrical issue causing the unit to lose its electrical insulation in time. This may as well be due to the heat.
A heat shrink tube -providing insulation- facing too much heat may may have melted.
If non of the above, try plugging in the other way -if possible, for European plugs, that is possible-. Or replace your faulty fuse / residual-current circuit breaker (RCCB)
Oct 28, 2013 | Microwave Ovens
My above ground filter is 20 years old. The plug from the motor just last year started to melt and the outlet also has a melted spot. What could be the cause?
Resistance is the cause. All heated material needs to be replaced. Cut back the wiring until you get to wire that has ZERO heat damage. Splice in at this point. This is a common issue. You just have to cut back until good material, and splice in replacement plug and outlet components.
May 14, 2011 | Pool & Spa
Two of the four hoods have had the plastic control parts melt. Hoods are 26.5 inches away from stove tops & is regular residential use. Breeze l, l l model # AK1224, 1200, 1238
Is it possible that the fans were not ALWAYS on when using the stoves?
Also using the proper size ducting is important to make sure adequate airflow is possible.
If temperatures are getting to the point of melting plastic, that is VERY unsafe.
Make sure ALL hood fans are operating when ANY stove is on. Heat rises and INFARED energy can heat stuff at a distance.
Mar 26, 2010 | Zephyr Kitchen Ranges
I have a Dimplex CS1205. Plug hot and melted outlet cover.
Many people think melting plugs and outlets are caused by the appliance that is plugged into them. It is very likly that the outlet is worn or loose or wiring connections are loose or the receptical is faulty. Arcing is a major cause for this condition and all of the above issues can cause arcing. This condition usually only happens when high draw appliances are plugged into the outlet. So a lamp could work fine in the outlet for 10 years then a toaster or heater is plugged in and a loose connection causes current to jump from the receptical to the plug prong which inturn causes tremendous heat.
Jan 11, 2010 | Dimplex Compact Electric Flame Stove...
I was roasting a chicken in my Maytag Cooktop when I heard a loud buzzing and a "pop", all of the power in my house went out. Something had tripped the breaker. My husband reset the breaker but my stove...
there is a short for sure, sometimes when the heating element burns out and melts, it touches the metal inside the housing causing a short. inspect the heating elements in the oven(top and bottom). the loud buzzing sound is what a shorting out heating element makes as it melts like a weldin rod, usually because of using tin foil(not recommended)
Jun 15, 2009 | Maytag MEC5430BDS Electric Cooktop
Covers over cooking/night lights are melting
I have a microwave above my stove also but it has not done what yours is doing. I would try a lower watt bulb since it would not give off as much heat. You may need to replace the lens or else just take it out and get rid of the problem altogether. You would have a brighter light anywas even if you kept the same bulb. Most of those bulbs are florescent and do not put out much heat anyway and seldom cause heat problems, esp. giving off enough heat to melt something.
Apr 17, 2009 | Microwave Ovens
The heater plug melted
Induction coil heaters draw very high amperage (12-14 amps) when turned on. If your outlet is worn or old the heater plug prongs will not have a good connection and the current will jump or arc from the outlet to the heater plug prongs. This arcing causes tremendous heat, enough to melt the outlet and the cord end. First thing to do is change the outlet.
Jan 31, 2009 | Dimplex Compact Electric Flame Stove...
Dimplex Compact Electric Flame Stove Heater Logo
324 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
