Question about Razor MX500 Dirt Rocket
Chain is turning but the rear wheel is not moving
What??? RLtoFixYa doesn't know what they are talking about. Your problem is a faulty/broke "one way roller clutch" which is threaded onto the rear wheel. I've already replaced 2 on my son's MX500.....
Posted on Jul 19, 2011
  • james o Nov 14, 2011
    yes i have a 4 month old mx500 and it is the roller clutch..they make them poorly..you need to buy the entire wheel assembly because it is welded on to the wheel..good luck...
    Scholar:
  • 52 Answers
If the chain is moving but the wheel is not there could be a few different things wrong.
First and foremost ensure that the chain is on both the front and rear sprocket. If it is not on both correctly by the teeth of the sprocket in the links of the chain then the wheel will not spin.
If the chain is on the bike, check to ensure that the bike is in gear or the clutch is disengaging. This will be a bit more difficult and technical know how. Ultimately, if the chain is not the problem you could have clutch or transmission problems. Both will require the engine to be removed and inspected internally.
Hope this helps.
Posted on May 26, 2011
I tried the WD-40 solution but no luck. My MX500 was less than a week old. I called Razor's US hotline at 866-467-2967 and they are UPSing me a new rear wheel assembly for free. They did ask if I tried the WD40 and I explained I had. The operator said the rear wheel assembly was probably "stripped out."
Ps: I saw a YouTube video of the welded wheel. I think it would work but potentially cause more problems down the road. The intent is for the chain to be able to spin backwards - also, the weld would cause a lot of torque that could burn out the motor. That's just my opinion though.
Posted on Dec 31, 2013
    Problem Solver:
  • 8 Answers
It is the rear freewheel assembly causing the problem. if is fixable, but you have to be good with tools, the bicycle shop and the electric bike shop both said they couldn't fix it, but is is doable. 1. you need a special bmx tool that fits that back wheel, your local bike shop should have it in stock. 2. you need to remove the freewheel sprocket and disgard it along with the the bearings (make sure to unscrew the razor chain sprocket from the freewheel assembly and secure it for reuse). 3. either purchase a new freewheel sprocket for bmx wheel or remove one from a old bike (again you will a special tool for that). 4. screw the razor chair sprocket onto the new BMX sprocket (it goes on with the same 4 original screws, right over the sprockets. 5. Screw the freewheel back onto the rim now. tada its fixed.
Posted on Jun 12, 2012
3 Suggested Answers
voodoomox
  • 1689 Answers
SOURCE: Chain and Wheels
thank you for using Fixya. the issue you are experiencing is pretty much your free wheel. If it is new, it may have been installed the other way around or the clip in the assembly that serves as a spring for the chainwheel to lock out has been worn out.
Best if you will be able to remove the rear wheel and then check the whole rear hub assembly starting with the freewheel and the axle.
Posted on Jan 04, 2009
  • 85 Answers
SOURCE: wheel does not turn when peadalled
needs a new sprocket on the wheel the teeth inside are worn
Posted on Oct 12, 2009
Bought a 03honda cbr 600rr, front sproket had been changed out and rear tire moved back. chain is loose 2"+ in slack but i can not move tire back any further in swing arms. can I move rear tire up and...
hi, prob good idea with this will be to slacken off the wheel push the wheel forward and fit a chain the correct length for the set up you have, count the links in the chain you have on the bike and get one 2 links shorter, mark a link on the chain with paint or sim turn the wheel and count the link plates, ie 1 plate is 2 links, so start on the 1 next to the marked 1 turning the wheel counting the plates 2 4 6 8 10 etc and end on the marked 1 this will give you the number of links already on the bike
Jan 15, 2011 | 2003 Honda CBR 600 RR
Won't just stay in one gear. constantly doing gear changes on its own. Hardrock. Rear set, reguardless of which front gear.
This happens when the back wheel is not aligned properly with the chain. As the wheel turns the chain is being pulled to one side causing it to slip to the next set of cogs. To solve the problem first you need to loosen the wheel by opening the 2 nuts on the axel. If the chain slips inwards towards the wheel you need to move the front part of the back wheel to the left from a view point behind the bike. If it slips outwards away from the wheel then you need to move the front of the back wheel to the right as viewed from behind the bike. When the chain and cogs of the rear wheel are lined up in a straight line the problem should be solved.
Dec 04, 2010 | Specialized Bicycle Components Cycling
I had to take off the rear weel of my falcon apache mountain bike to get it in my car o travel from my grandparens home to mine but i cant get the back weel gear arm back on. how do i do this??
By the "gear arm" I assume you mean that part of the rear derailer that the chain zig-zags through. This arm moves in two ways. It moves in and out (toward the wheel and away) as you move the shift lever - which is how it changes gears, by moving the chain onto different sprockets (gears). It also moves forward and back (toward the front and back of the bike) under spring pressure. This forward and back motion is necessary to take up the slack in the chain when you are using the smaller sprockets (the smaller the sprocket, the "higher" the gear). When the wheel has been removed, this arm moves forward (under spring pressure) as far as it can to take up all of the slack in the chain. All you have to do is grasp this lever and pull it toward the back of the bike, allowing the lever and the chain to pass behind the sprockets (gears) as you pull the wheel back into it's position. You can safely pull this arm forward and back at any time without doing any damage. One more tip-- I find it a little easier if you first put the shift lever in a "middle" gear position. Then when you pull the wheel into place, you should aim to put the chain on a middle sprocket. You don't have to hit the exact correct sprocket as you can simply lift the rear wheel and turn the pedals forward (after installing the wheel) and the chain will move to the correct sprocket corresponding to the setting on the shift lever.
Good luck! Please vote if you found this helpful. Al K
Oct 14, 2010 | Falcon Cycling
When i push the thumb control down the motor comes on and the chain turns but the rear tire does not what is causing this? thank you
sounds like you need a new rear wheel as the wheel locking mech has been stripped or damaged where the cog is at. Can you move the wheel forward and backward with out the chain moving? If so that is your problem.
Sep 28, 2010 | Razor E300 Scooter
Loose chain
Loosen the axle nut and the lock nuts for the chain adjusters on each side of the swingarm. Turn the adjuster to move the rear wheel to the rear to tighten the chain.
You want to adjust the chain so that you have 1 inch up and down play in the chain. By this I mean 1/2" above center and 1/2" below center of the chain as it sits on the bike, 1" up and down inclusive. Adjustment should be made at the point where the chain is the tightest. Roll the rear wheel while checking the chain tension. Find the tightest point to make your adjustment.
Move both chain adjusters the same amount to keep wheel straight within the swingarm. Once adjusted, roll the wheel a couple of turns and check the adjustment of the chain again. Once finished, tighten adjuster lock nuts and retorque the axle nut to 50 foot pounds of torque.
Good Luck, Steve
May 09, 2010 | 1993 Harley Davidson XLH Sportster 883
What is the correct chain tension for a CBR600f? (2002)
Using a tape measure (or visual estimation, if necessary), grasp the chain at a point halfway between the front and rear sprockets, and pull it up and down. The chain should be able to move roughly one inch up and one inch down. If your motorcycle is on a rear stand or centerstand, note that the swingarm will drop if the wheel is lifted from the ground, which will affect the rear geometry and the tension in the chain; compensate accordingly, if necessary.
Because motorcycle chains can stiffen in certain spots and stay pliable in others, it's important to roll the bike forward (or turn the rear wheel if it's on a stand) and check all sections of the chain. If it moves more than about an inch, the chain will need tightening, and if it's too tight, loosening will be in order; this is outlined in subsequent steps. If individual chain links are too tight, the chain might need replacement.
Mar 10, 2010 | 2005 Honda CBR 600 F
Chain
Using a tape measure (or visual estimation, if necessary), grasp the chain at a point halfway between the front and rear sprockets, and pull it up and down. The chain should be able to move roughly one inch up and one inch down. If your motorcycle is on a rear stand or centerstand, note that the swingarm will drop if the wheel is lifted from the ground, which will affect the rear geometry and the tension in the chain; compensate accordingly, if necessary. Because motorcycle chains can stiffen in certain spots and stay pliable in others, it's important to roll the bike forward (or turn the rear wheel if it's on a stand) and check all sections of the chain. If it moves more than about an inch, the chain will need tightening, and if it's too tight, loosening will be in order; this is outlined in subsequent steps. If individual chain links are too tight, the chain might need replacement.
Nov 20, 2008 | 2003 Harley Davidson FLHTC Electra Glide...
Chain
Nov 20, 2008 | 2008 Harley Davidson FLHRC 105th...
Razor MX500 Dirt Rocket Logo
1,719 people viewed this question
Top Razor Cycling Experts
Ted Maxwell
ray gallant
 steve
steve
Are you a Razor Cycling Expert? Answer questions, earn points and help others
