Blue screen and aleatory restart. I have a SONY VAIO VGN_NS135E with Vista Home Premium. Memories checked - ok Hard disk checked - ok (tried with another one)
    Sergeant:
  • 228 Answers
If you've tried to use your harddisk to another computer and it didn't restart nor got a BSOD, the motherboard may be failing. I have seen some laptops doing the same thing and it was corrected by replacing the motherboard. However, try to reload the BIOS default settings and reinsert the memories if you have not tried it yet (since you have not indicated if you reseated it or just ran a diagnostic check).
Hope this helps.
Posted on May 25, 2011
Laptop goes off when plugged in
mine did that (I'm using it now)
I ran a check for updates, installed all, restarted, checked again for updates, installed 2 more, restarted, all was normal again
Nov 06, 2013 | Sony VAIO VGN-NS135E/S Notebook PC
Vaio VGN-Ns135E fn key doesnt work
Visit the below page, select appropriate operating system and install the Sony Shared library and Sony Notebook Utilities.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNNS135E&SelectOS=28
Also ensure that the services are started for VAIO Event services.
Press Windows logo key + R key to open Run window.
Type "services.msc" without quotes.
Locate the VAIO Event services from list and set it to automatic and started.
May 28, 2011 | Sony VAIO VGN-NS135E/S Notebook PC
My sony vaio vgn-cr220E was uprraded from vista to windows 7..why does the biult in motion eye camera doesnt work..
You need the Win7 camera driver, check sony support at:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220E&SelectOS=44
just enter your Win7 operating system (there are 9 versions of Win7), and select the downloads (2)
for your computer camera driver.
Versions of microsoft Win7 - determine which yours is by (these instructions are for WinXP);
START > Control Panel > System > General (tab)
Windows 7 Home Basic 32-bit
Windows 7 Home Basic 64-bit
Windows 7 Home Premium 32-bit
Windows 7 Home Premium 64-bit
Windows 7 Professional 32-bit
Windows 7 Professional 64-bit
Windows 7 Starter 32-bit
Windows 7 Ultimate 32-bit
Windows 7 Ultimate 64-bit
May 14, 2011 | Sony VAIO VGN-CR220E/P Notebook
Sony vaio vgn series laptop - when xp os loading blue screen appears and display the msg hard disk drive not detected.
system not found in my experience generally leads to a damaged or loose hard drive, try to open the cover at the bottom side of the machine, and reseat the hard drive, if it still says system not found, get a 2.5 inch drive case, put your laptop drive in the case and connect it to another machine, if you can access the drive great! save all your files and once complete return the drive to your machine and try to reinstall the OS from a dvd then reinstall your files.. and if still having the same problem replace hard drive thanks.
Oct 26, 2010 | Sony VAIO VGN-NS135E/S Notebook PC
Vgn-nr185e (sony vaio) read error.. alt+ctlr+del to restart
what are you using to reformat the hdd? if you havent formatted the hdd using any retail version of od disc, youmay try to access the vaio recovery partition.. that is when you restart the computer, then press f10 key repeatedly for 5-7secs. it will load vaio recovery center. then from there, select restore c: drive. follow on-screen instruction and it will format the hdd. process may take for 45mins up to an hour
Mar 18, 2010 | Sony VAIO VGN-NR180EW Notebook
Need service manual or instructions on replacing hard drive on a Sony Viao VGN-ns135e or Sony VGN-NS100 Series Laptop
The hard drive is inside of the laptop and not accessible from the outside. The way to get to the hard drive is to take out all the screws from the bottom of the laptop, take the keyboard out and there may be some screws there that need to be removed. The dvd drive needs to come out and where the dvd drive normally is, check for screws there.
At this point you can remove the top cover assembly and you will see the hard drive. Remove the screws that are holding the hard drive in place and then it will come out.
Nov 30, 2009 | Sony VAIO VGN-NS135E/S Notebook PC
VAIO VGN-AR630E Drivers for Vista Ultimate
Vista Home premium drivers will work perfectly with Windows Vista Ultimate. When installing Vaio event service and Vaio Control center make sure that you run setup file as administrator. Right-click the setup file and select option "run as administrator". By reinstalling utilities this way they will work perfectly well
May 17, 2009 | Sony VAIO VGN-AR630E Notebook
Vista home premium edition keeps rebooting
its nothing u have downloaded the updates for ur system while ur restarting the updates will install so wait some time nothing will happen for data
Feb 25, 2009 | Sony VAIO VGN-NR120E/S Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
