Question about Pioneer Audio Players & Recorders
Need to no the code for bluetooth phone setup
  • 1,116 Answers
0000
Posted on May 25, 2011
How do i get code for bluetooth
First make sure that Bluetooth is on on the CDE-143BT. Press and hold Audio/Setup (below and to the right side of the rotary encoder dial until you enter the Setup mode. Use the rotary dial to get to Bluetooth. Press the Search/Enter button (the center of the rotary dial). Then use the rotary encoder to go through the Bluetooth Settings menu. Press Search/Enter to toggle the current value. After Bluetooth is on, go to Visi M setting and make sure that it is on. Now, you need to go to the Bluetooth settings area of your cell phone when it is within range of the receiver. Tell it to pair with the receiver. Then when it asks for the code enter "0000". This code is hard encoded into the unit. See page 23 of the manual for the CDE-143BT for the code. The manual is available here: http://vault.alpine-usa.com/products/documents/OM_UTE-42BT_CDE-SXM145BT_CDE-143BT_EN.pdf . Surrounding pages show setting the other Bluetooth settings.
Note: the receiver will be acting like a Bluetooth headset. That's why you need to enter the receiver's PIN on the phone.
I hope this helps.
Oct 10, 2014 | Alpine CDE-143BT Advanced Bluetooth CD...
How to pair your phone to the bluetooth on th kenwood kvt-514
Go into your Setup menu and scroll down to bluetooth settings.
From here you should see a screen that says "HFP connect device", "A2DP connect device" and "Receiver pin code".
Press the "Set" button to the right side of "A2DP" and it should bring you to another screen that says Pair device.
Go onto your phone settings and make sure you have your bluetooth setting on your phone set to "make discoverable"
Press the search button on the Kenwood unit on the right side and it will start scanning for available devices in the vicinity
Also press the Search button on your phone so it also starts scanning.
Next you should get a message on both your phone that shows the Kvt-514 and also a message on the Kenwood that shows either the model of your phone or your "nickname" (if you named your phone)
Select the Kvt-514 on your phone and it will prompt you for the pin code that was on the first bluetooth setup screen...most likely 1111 (you can also set a different pin code using the "set" button to the right side of the "Receiver Pin Code" on the first bluetooth setup screen)
Enter the Pin code and select "Pair" on your phone.
You should get a confirmation on both the Kvt-514 and your phone that they are connected and you're good to go.
Apr 02, 2011 | Kenwood KVT-514 Car DVD Player
Dont know how to install my bluetooth
need to find setup then pair your bluetooth following the instructions, if when asked for pass code and your not sure enter 0000. the phone and bluetooth will do the rest.
Jan 16, 2011 | Cell Phones
Need pass code plantronics voyager 520 to pair with a new phone
For all current Bluetooth headsets the passkey is 0000 (four zeros).
If the phone does not accept this code, please refer to your cell phone user's guide to ensure the proper setup procedure.
Note: Powering your cell phone off and on sometimes corrects this issue. You cannot change or personalize the PIN code/password of the Bluetooth headsets. It will always remain four zeros.
Good luck from Headsets Direct!
Dec 29, 2010 | Plantronics Voyager PRO Bluetooth Headset
How do i find my bluetooth pin code on my fone?
There is no specific code or passkey for phone's bluetooth, it's only used for once setup and you can use any code during the establishment of the connection. The only thing is that you should use the similar code on both the pairing devices, suppose if you type in 11 on your phone, then you have to type in 11 on the other phone or bluetooth device (when asked).
If you need further help, let me know with more details.
Good luck.
Thanks for using FixYa.
Sep 06, 2010 | Samsung Cell Phones
How to setup hands free phone support
as long as you have a compatable phone (consult your dealer for confirmation) make you bluetooth active on your mobile, then in pcm/phone settings search for phones. when it locates your phone it will ask for a code to input. type this into your phone and it should pair via bluetooth. you are now ready to make and receive calls via your pcm
Nov 03, 2009 | 2005 Porsche 911
Bluetooth h700 setup
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to thephone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized. After this, it will ask for a passcode.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Aug 20, 2009 | Motorola Mobility Bluetooth Car Charger...
Need to setup H300 bluetooth to my LG VU phone! How do I do this?
The quick answer is that you can put it into pairing mode, and your phone should recognize it. To put into pairing mode, push and hold the large power/answer button for at least 6 seconds. The light will start flashing, indicating that it is in pairing mode. Go into the Bluetooth menu on your phone and make sure Bluetooth is turned on, that your phone is visible, and that you can search for new headset devices. Make sure the headset is still flashing. When you discover the headset in the phone, it may prompt you for the code. I believe the pairing code is "0000". Add the device to the phone. You should now be able to use it with your phone.
If this doesn't get you there, do a search for H350 Manual to get a pdf of the user manual and quickStart guide.
Jan 08, 2009 | Motorola Mobility H300 Wireless Headset
Code for bluetooth car kit
Also note that some of the IHF1000 carkits may also use 1234 for the passcode. When you go into the Setup Menu and ask it to Pair a Phone, the prompt will tell you the correct passcode (0000 or 1234) to enter by saying, "Enter xxxx, when requested".
Nov 24, 2008 | Motorola Mobility Blnc Bluetooth Car Kit...
48 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
