Question about Garden
Weed eater xt 260 choke lever is broken...can it be replaced easily
    President:
  • 1,545 Answers
It is not listed as a replacement part on the carburetor. You would have to remove the choke plate, and the choke shaft from the carburetor. These parts are press-fitted into the carb housing and the choke lever is also press fitted onto the choke plate shaft.
Posted on May 25, 2011
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    My Weed Eater FL1500LE gas leaf blower will not run beyond the full choke setting. If I move the lever to half choke the engine will stop. Or if I move the throttle from full throttle to a lower speed...
    This is a tell tale sign of a lean fuel mixture. By choking the unit you are manually creating a richer fuel mixture. I would purchase a compression tester from a local parts store and check compression. If that's ok, I'm willing to bet the problem is still carb related. Two stroke carbs are tricky to clean because of high/low ports that are one way and sometimes impossible to clean. Did you remove high and low needles when cleaning carb? Another trick is to mix seafoam with your gas, then mix two cycle oil to proper ratio. Use 2 ounces seafoam to one gallon of gas, then mix two cycle oil to proper mix. Hope this helps! Good luck and happy wrenching!
    Sep 22, 2013 | Weed Eater Fl1500 Le Leaf Blowers
    Air filter replacement weed eater
    on your weed eater there should be a lil bubble looking thing called the primer somewhere around tht should be a black box with a screw of some sort on it take the lid to the black box of and theres your air filter
    Aug 17, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
    Can't find owners manual for the following weed eater model numbers xt-200, xt-260 and poulan model # p35oo
    XT200: http://www.weedeater.com/ddoc/WEEO/WEEO2004_USen/WEEO2004_USen__530163333.pdf
    XT260: http://www.weedeater.com/ddoc/WEEO/WEEO2010_USen/WEEO2010_USen__545186831.pdf
    P3500: http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2007/NOUS2007_545154718.pdf
    Sep 06, 2011 | Garden
    What is the current oil/gas mix for the excalibur 22" hedge clippers? How about the new oils like Echo an Brigg/stration that are used at 50/1. Would 50/1 be acceptable in the weed eater excalibur?
    50:1 is 50:1 no matter whose 2 cycle mix you use. 50:1 is 2.6 ounces of 2cycle mix to 1 gallon (US) of gasoline. I recommend strongly to use a brand that contains fuel stabilizer. It will come in a 3.2 ounce bottle...still 50:1. The premium 2 cycle oils will be semi-synthetic or full synthetic and will claim "no smoke"
    Sep 27, 2010 | Weedeater Excalibur Gas Hedge 22" Trimmer...
    Weed eater starts but won't stay running
    just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
    Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
    Poulan ppb 250 weed eater, only runs with choke on,
    HOW IS YOUR FUEL LINES. SOUNDS LIKE IT MAY HAVE A AIR LEAK
    Sep 20, 2009 | Garden
    31cc Ryobi weed eater engine will start, then stall shortly after
    you need to adjust the carb ,look for small screws around carb turn out 1/4 to 1/2 turn good luck
    May 24, 2009 | Black & Decker 19" Electric Lawnhog...
    Garden Logo
    128 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
