Question about Lexmark Office Equipment & Supplies
I try to print and computer is not communicating with printer.
    Scholar:
  • 81 Answers
Hi darin_I,
1) connect the power cord.
2) connect the communications cable.
3) add the printer.
Good luck.
Posted on Aug 16, 2008
SOURCE:
How can I get my mac to communicate with my printer?
reinstall the printer driver from the manufacturers web site as a lack of communication indicates a driver problem
next click on the printer > properties>compatibility tab> click box and highlight operating system on the computer and >apply
Jul 24, 2017 | Epson Workforce 615 AllInOne Printer
Not communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Dec 22, 2011 | Lexmark X1240 All-In-One InkJet Printer
"Communication Not Available" message is displayed
2. Unplug and re-plug the printer into the power source to reset it.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
Hi - my x4550 lexmark printer wont print, can you help?
If your printer won't print when you're making a copy using the Copy button on the operator panel, it could be due to your ink cartridges. Try to re-seat your ink cartridges into the printer and make sure they are properly seated.
If you're not able to print from your computer, it could be a communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to print again.
You may refer to this article for Wi-Fi connection issues: How to identify a Wireless Communication Problem and Resolution Tips
Aug 11, 2011 | Lexmark X4550 Multifunction Wireless Color...
My Lexmark Platinum PRO905 does ot print it gives me the message " Communication Not Available, The Printer cannot communicate with the computer"
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug your printer into the power source to reset it. When the printer turns on, reconnect the printer into the computer. Try to print again.
You may also refer to this article (for Wi-Fi connection issues): How to identify a Wireless Communication Problem and Resolution Tips
Aug 09, 2011 | Lexmark Platinum Pro905 multifunction...
My printer wont print at all
Are you able to make a copy using the copy button on the printer operator panel? If not, try to reseat your cartridges into the cartridge carrier. If yes, then the problem could be due to a communication failure between the printer and your computer.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Disconnect the printer from your computer. Reboot your computer. Unplug and re-plug your printer into the power source to reset it. When the printer turns on, reconnect it your computer. Try to print again.
You can also try to re-install the printer driver on your computer to repair any possible corrupted files necessary for printer communication and processes.
Jun 15, 2011 | Lexmark X1270 All-In-One InkJet Printer
Printer wont comunicate with Computer
Try to unplug your printer from your computer. Unplug and replug your printer into the power source to reset itself. When your printer turns on completely, reconnect to your computer. Try to print again. If problem continues, you may refer to these articles in the Lexmark website:
- Communication Not Available' Error Message and Print Job Stalls in Print Queue - No Communications Error When Trying to Print or Scan
I hope these help. Thanks.
Feb 16, 2011 | Lexmark P4350 All-In-One InkJet Printer
Communication between Computer and printer
Re-install driver/software. Re-start computer. What does device manager indicate?
Jun 27, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer not communicating with computer
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Jan 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470
When you got this message were you trying to scan?
What I want you to do is a copy. Doing a copy will generally not require you to be hooked to the PC.
Scanning and Printing all require communication from the printer to the computer. Failure in communication can either be something on the computer, something wrong with the cable or rarely something wrong with the printer.
I'm assuming you have done the following:
1. Power off your printer and your computer.
2. Unplugged the power from the printer
3. Unplugged the USB cable from both the printer and the computer.
4. Reconnect the USB cable to the printer and the computer.
5. Plug the power back into the printer and make sure the printer is on.
6. Turn on the computer.
Those are general troubleshooting steps that can be done for any communication problem.
If you have done all of those try this:
Press and hold down the Windows key on the keyboard, and then type the letter R.
Type "devmgmt.msc" and then click OK on the Run dialog.
Find the item Universal Serial Bus controller.
Click the + sign next to the word Universal Serial Bus controller.
Do you see USB Printing Support?
Yes:
Right-click on USB Printing Support, and then click Properties.
Does the Device status say “This device is working properly.”?
Yes:
Have you tried uninstalling and reinstalling the software?
No:
Click the Troubleshoot button to try to resolve the problem.
Does the Device status now say “This device is working properly.”?
Yes:
Try your print again (might need to restart)
No:
Might have a problem with your Printing Support
No:
Let me know - if you have a problem with your printing support you'd really need to contact your PC MFG for help - but you can always try uninstalling the USB Printing Support and reinstalling it (only if you have your disks that came with your printer).
Sep 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
