Question about JVC Car Audio & Video
I have a JVC KW-AVX830, It has worked fine for 7 months but when I got in my car to go to work about a week ago my stereo's volume started turning up by itself to the highest level and when I turned it down it would just turn right back up... NOW (1 week later) my stereo doesn't even turn on AT ALL NO MATTER WHAT...(the power button lights up when car is on but nothing else.. FINALLY, when I push the RESET button it just sounds like the
  • Corolla2312 May 26, 2011
    (cont) the motor that "tilts and opens the tray is just spinning and the unit remains off... PLEASE HELP!!
  • 63 Answers
SOURCE: Volume control unresponsive
The LED didn't turn on ,indicate the DC pwr was missing , you need to ensure there is a Dc supply to the speaker unit,once you got the LED on you will be able to control the volum.
Posted on Aug 09, 2007
  • 26 Answers
SOURCE: Faceplate not working
Try disconnecting the unit completely.
Posted on Nov 09, 2007
SOURCE: won't turn on
The door switch is definitely not the problem if the indicator lights are not coming on. These lights are supposed to come on when the door is open.
The problem is 1 of 3 things:
1) No power to outlet that DW is plugged into;
2) Bad connection where power cord is connected to dishwasher (see very bottom front, under kick panel)
3) Some problem internal to the DW (eg., bad switch, shorted wire, etc., )
Our SHX46A is definitely having problem 3, but Bosch's manual gives zero help. So, off to find more info online or, lastly, to call Bosch repair person. Sigh.
Posted on Feb 24, 2008
SOURCE: Volume go up to MAX, power button does not work
what is a tact switch and can i change it myself?
Posted on Mar 20, 2008
  • 3 Answers
SOURCE: HELP STEREO CUTS OUT!
ok , ive found the problem with mine. I checked the voltage between the earth wire on the head unit and the battery in the car. I found that when i turned the headunit up to around 17-20 there was up to 3volts differance, which is when it would cut out. So ive run a new earth wire and she's all sweet . Even the cd player works now.
Posted on Aug 19, 2008
JVC CAR STEREO DECK MODEL NUMBER KW-XR810 ONE WEEK AFTER INSTALLTION OFF KENWOOD AMP DECK STARTED SKIPPING AROUND ON THE PRESET CHANLES AND.THIN THE CD IN THE DECK STARTED PLAYING NOW THE CD IS STUCK IN...
It sounds like you may have a stuck or bad switch. Try checking to see if any of the buttons are jammed. If they all seem fine, you will need to check the switches with a multimeter set to check resistance.
Dec 30, 2014 | Car Audio & Video
Jvc kw avx840 frozen on telephone screen. Press reset and everything works fine again until either detatch facia or switch off ignition.
Sounds very strange ... I have the exact same set. Try removing the Bluetooth dongle and re installing it again and see if this helps. Is this a new install? You r ground is good right? to the frame not just a black wire from old stereo you replaced?
Apr 21, 2014 | JVC Kw-Avx840 7 Double-Din Multimedia...
JVC KW-AV71BT wiring diagram
My ipod jack used to work, I unplugged ipod then plugged it back in. Now it shows on the screen that the ipod is connected and playing, but now sound comes out. This is only on ipod, everything else works fine
Feb 02, 2014 | JVC KW-AV71BT In-Dash DVD/MP3/USB 7"...
Jvc kw avx820 no sound
Check the speaker connections it looks like there may be a feedback signal going back to the internal amp. If those are fine then the amp itself is clipping and you need to have the player checked.
Apr 03, 2012 | JVC KW AVX820 Car Video Player
KW-NW7000 "lost GPS signal"
New FW 1.3.4.0 is posted as of Sept 2009
Jun 27, 2009 | JVC KW-NX7000 Car DVD Player
KW-NX700, constant "lost gps signal" all of a sudden!
Hi,this problem exist because the navigation is bloqued, if reset the problem is the same.
The solution for this problem is:
desconect de battery car, and wait 15 minutes
conect the bactery, work`s fine
cumps
Luis Gabriel Portugal
Lutrónica
Dec 12, 2008 | JVC KW-NX7000 Car DVD Player
Car Audio & Video Logo
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
