Question about Compaq Computers & Internet
I think my hard drive died on my Compaq Presario C500
    Problem Solver:
  • 4 Answers
Bash it with a hammer
Posted on Aug 16, 2008
How to clean the fan air
Regular maintenance of your Compaq Presario laptop helps to keep the machine running properly.
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
or Remove an HP Presario C500 Fan Assembly to clean it
HP Presario C500 is a laptop that, like most other laptops, requires a clean, functioning fan in order to work properly.
If your fan is too full of dust to function properly or needs to be replaced because it is no longer working, then your computer could be in danger of overheating and crashing.
Instead of having to purchase a new laptop because your C500's fan has failed, remove it and clean the fan or replace it with a new one.
Turn off your computer and unplug all the cords and cables from it, even the power cable.
Turn the laptop over and remove the battery, then remove all the screws at the bottom of the computer with a Phillips-head screwdriver.
Remove the two face plates from the bottom of the computer and you'll see the hard drive and RAM below.
The face plates will come out easily once the screws are removed.
Remove the two screws holding the hard drive in place and then lift the hard drive out.
Remove the screw found directly below the hard drive.
Turn the laptop over again and pop off the keyboard.
If all the screws at the bottom of the computer where removed, then the keyboard will come right out.
Remove all the screws underneath the keyboard and case and then lift the case enough to access the fan assembly in your HP Presario C500.
Unhook the cable coming from the fan into the motherboard and remove the screws holding the fan in place, then pop the fan out of the computer.
Hope this helps
Oct 20, 2012 | Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD...
Compaq presario c500 err2err3
This issue could be due to hard drive or due to Recovery partition. In order to isoalte and resolve this issue I request you to perform the below steps :
Please follow the steps given below to run the hard disk self test:
1. Restart your notebook.
2. Press F10 key when you see Compaq Logo.
3. Using the arrow keys navigate to Diagnostics Menu.
4. Select Primary Hard Drive Self Test.
5. Click Enter
This may take up to 55 minutes.
Please get back with the result
Feb 05, 2010 | HP Compaq Presario v3000z Notebook
Compaq c500 wont boot. Startup repair cant repair automatically.. i need help please
check your startup list to see that the hard drive is in hte list of boot drives and that it is on the top of the list
Thanks!
Stan Skaggs
Nov 23, 2009 | HP Compaq Presario C500t Notebook
The CD drive in my sister's compaq presario c500 died...can i take the CD/DVD burner out of a toshiba satellite and put it in her compaq?
There is no real standard for laptop CD/ROMs I have seen some mount with screws and some that pop out with a tab. I am almost sure it will not work. You can either get an external USB cd from Wallmart or spend the money to get a replacement from the manufacturer.
Sorry about the bad news.
Sep 14, 2009 | HP Compaq Presario C500t Notebook
When I try to put XP on my Compaq Presario C500, it cannot find the hard drive and will not try to load it. I have already done a diagnostic on the hard drive and it is working perfectly. What can I do?
I take it that the hard drive is a not the normal IDE but rather a SATA (newer technology) drive. Inthat case you can in some cases change the Hard drive setting in the CMOS setup from ENHANCED to IDE-MODE under STA drives. That causes the installation to detect the drive as an 'IDE" drive in which case it then can install windows. The normal windows installation cannot always detect SATA drives while installing and then reports that there is NO drive attache to the computer
Jul 06, 2009 | HP Compaq Presario C500t Notebook
Fast Blinking Power Button
Check your RAM. I had the same problem with my C500. I ended up having a bad stick of RAM. The only other cause I know of is the hard drive. Although this is rare if you had no problems with your operating system before.
May 16, 2009 | HP Compaq Presario C500t Notebook
Compaq c500 blank screen, can heard hard drive running
You should replace the power supply, and clan out dust, and tighten connectors
Mar 11, 2009 | HP Compaq Presario C500t Notebook
Compaq presario C500
if you don't have driver disc,then you can find it in driver databases
Feb 03, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq m2000 boot problem
i suggest you go to bios setup and restor the default if it continues try replacing a diff hard drive or dvd drive drive thats not the one u r using rigght now and i think the problem will be resolved cos i had a similar problem with presario c500 what i did was change the dvd drive n it work well.
hope this helps
thank u for using fixya
May 27, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
