I have data traveller 200 128Gb.windows says "do not regognice" or something. it won't work! i think i need drivers, but where i can get them????????
  • 4 Answers
The Kingston Datatraveller 200 is a counterfeit. They are not actually made by kingston, and are a fake product being sold to scam people. I'm sorry, but you'll have to return it.
Posted on May 25, 2011
Keyspan's drivers won't work on Win7 . . . Install MS's Virtual PC. Add usbd.sys to windows/system32/drivers (virtual box doesn't think it needs to load the virtual usb drivers, so i
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose vista sp2
now run it and presto......
regards, dean
Jul 06, 2012 | Keyspan USB Server US-4A (d47710) Print...
Tip
Backup data from non-booting operating system
You go to boot your computer and you get an error. Asking around online you find out that the only thing left to do is to reformat and reinstall the operating system, causing all your data to be lost. Is there nothing you can do? Actually, yes there is. I will explain how to use the <a href="http://www.sysresccd.org/Download">System Rescue CD</a> to save your data, then restore it on the new installation! This can be done with any linux live CD, but the system rescue CD is a little easier, so that's what I'll use to explain it.<br /><br />What You'll Need:<br /> <ul> <li>System Rescue CD</li> <li>External USB drive LARGER THAN your internal drive (or at least equal to)</li> <li>Some time and patience :)<br /></li></ul> <ol> <li>Download the .iso file from the website linked above, then burn it to a disk. This will give you a working copy of the System Rescue CD. You'll want to download the latest working copy, listed as the "Final Stable Version". It will always be on top (at the time of writing it's <b>2.3.0</b>).</li> <li>Insert the disk into the non-working computer. You might have to turn it on and quickly open the CD drive to put it in. Then restart. Depending on your system, it might boot to the CD automatically. If not, look around when you first boot for "Boot Menu" usually on the bottom of the screen, it will tell you which function button to hit. F7, F9, F10, F11, Esc, and Del are popular ones. Try different buttons, you can't hurt anything, and if it doesn't work just hit Ctrl+Alt+Del to restart and try again.</li> <li>When it finally boots to the CD, keep pressing enter until you get a prompt that reads "root@sysresccd / %" that means you're at the command line. Now there are two ways to go, using the command line and using the GUI. I'll explain the command line first, then the gui.</li></ol>Command Line:<br /> <ol> <li>(NOTE: All commands will be surrounded by "double quotes". Do not type the quotes.) Type "fdisk -l /dev/sda" and take a look at the partitioning scheme. There should be at least one partition, formatted NTFS. Most of the time it's sda1, but it could be that you have one small partition and one large one. You need to figure out where your windows partition is, so you can back the data up. Pick which one you think it is (I'm going to assume sda1) and type "ntfs-3g /dev/sda1 /mnt/windows", then type "cd /mnt/windows" then "ls" (NOTE: that's an "ell", not an "eye"). If you see some windows directories (like Program Files), you've got the right partition. If not, type "cd /mnt; umount /mnt/windows" and retry.</li> <li>When you have your windows partition mounted, plug in your external harddrive and wait a minute or two to be sure that it's recognized.</li> <li>Type "dmesg". A lot of text should scroll, then it should put you back at your command prompt. In the last few lines you should see something like "USB Mass Storage Drive entered: sdb" or something similar. The important part is the sdb. Type "fdisk -l /dev/sdb" again to look at the partitions (there should only be one), then type "ntfs-3g /dev/sdb1 /mnt/backup" to mount it as the backup disk.</li> <li>Type "mkdir DataBackup" to create the folder to store the backup in, then type "cd DataBackup" to change to that directory.</li> <li>Now type "rsync -av --progress /mnt/windows ./" to copy everything from the windows directory to the DataBackup directory. Wait until it's done, then reboot.</li></ol>GUI:<br /> <ol> <li>Type "wizard" at the command prompt, then keep hitting enter until you get a gui. Go through the "start menu" until you find something called gparted. Open that and take a look at everything you've got.</li> <li>On the top right you'll see the drive you're currently perusing. sda is your internal drive, sdb is your USB. Right click on the largest box under sda and click "Mount". It should give you a dialog box, choose the directory /mnt/windows. Do the same for sdb, mounting it at /mnt/backup.</li> <li>Open the file manager (it should look like a folder on the taskbar). In the left pane, navigate to /mnt/windows, in the right, navigate to /mtn/backup.</li> <li>Create a directory in the right pane named DataBackup (should be able to right-click&gt;New Folder), then open that folder.</li> <li>Select everything in the left pane and copy it to the right using the button in between the panes. You can hover with the mouse over the buttons to see what they do.***</li> <li>Wait until the transfer is complete, then you've got your backup!</li></ol>*** If there is an error that sdb is not writeable, open the command prompt (should have opened when you started the gui) and type "umount /dev/sdb", then type "ntfs-3g /dev/sdb1 /mnt/backup". That will make it writeable.<br /><br />You can use these folders to copy your data back off once your installation has been fixed. Note that you cannot copy over programs, only data such as saved files, pictures, movies, etc. The programs will have to be reinstalled. Best of luck, and I hope this helps someone!<br /><br />
on Aug 18, 2011 | Computers & Internet
Tip
What Is A Driver, Why Isn't Mine Working and Where Do I Get One
<i>What Is A Driver and Why Won't Mine Work?</i><br /> <br />A driver is software, a program, that allows your computer to <br /> communicate with hardware or devices. Without drivers, the <br /> hardware you connect to your computer&shy;for example, a video card or <br /> an audio card, printer etc will not work properly. Think of it <br /> like driving a car. It doesn't help to just turn it on if it's <br /> only going to sit there in the parking lot. It needs to know <br /> where to go and how to get there and what to do.<br /> <br /> <i>It Looks Like I Have One, But It's Not Working--- Why?</i><br /> <br /> <br /> There are several reasons why you can have a driver installed but<br /> the device doesn't work. If it was working but now it's not the<br /> file - driver - may have gotten corrupted. The resolution is to <br /> reinstall the driver. If you have installed a new version of <br /> Windows it may not work with the old driver. You will need to <br /> download a new driver for the specific version of windows you're <br /> using.<br /> <br /> <i>Where Can I Get One?</i><br /> <br /> <br /> The best why to get the proper driver for your device is to go to <br /> the manufacturer's website and download it for the particular <br /> operating system (ie windows vista) you are using. If you have a <br /> laptop start by going to Google or another search engine and <br /> SEARCH for the brand name of your laptop, ie "toshiba". In the <br /> results look for "support" or "downloads". If you dont' see <br /> that listed in the search results then just to to the main site, <br /> ie toshiba.com and then look for a tab or link (usually at the <br /> top of the page) that says SUPPORT or DRIVERS & DOWNLOADS.<br /> <br /> Once you get on the proper page of the site you will need to match <br /> the exact model of laptop you have and the operating system you <br /> are using. It will then take you to another page that has a list <br /> of drivers and other downloads available for your laptop. Look <br /> for the one you need and download it.<br /> <br /> If you are needing a driver for a desktop or an add-on device for <br /> your laptop, such as a printer, then SEARCH on Google or Bing <br /> for the manufacturer's (name) site, ie "epson". Again you're <br /> looking for SUPPORT or DRIVERS and Downloads. Click on that link <br /> and then put in the model number and operating system to get the <br /> correct driver.<br /> <br /> On occasion your machine may not like a new driver but will work <br /> if it is "rolled back" to an older version or you may need to <br /> download an older version. If you are downloading an older <br /> version you will still want to make sure it is one for the <br /> operating system you are using now.<br /> <br /> If everything has been working correctly you may wish to turn off <br /> the auto-download updated drivers in your WINDOWS UPDATE so that <br /> it doesn't automatically replace the driver with a new one. <br /> <br /> By the way, it is NOT necessary to update some things immediately <br /> when they come out! That includes not only drivers but also such <br /> things as Internet Explorer. I prefer not to be a "beta-tester" <br /> for some things without my knowledge, particularly when what I've <br /> been using works fine. Often there are still kinks being worked <br /> out in the new versions but if you wait a short while they will <br /> start being reported and hopefully the bugs will be fixed, then <br /> you can download it. It's not a bad practice to search google <br /> for " (updated product's name) and problems. For example you'd <br /> put this in a google search __ "interent explorer 9" problems <br /> ____ which will give you a return of sites that talk about <br /> problems other's have had with the product. <br /> <br /> <b><i>NOTE:</i></b> there are always some people/machines that will have a <br /> problem with something that most others don't, so don't <br /> necessarily assume that one bad report means the software is bad. <br /> However if you see repeated reports of the same problem again <br /> and again you can pretty much guess that it's the software that is <br /> causing the problem! If that is the case I would avoid updating <br /> it until you've searched again at a later date and find either no <br /> current mention (look at the dates) of repeated problem or reports <br /> of a fix.<br /> <br /><br /> <br />
on Aug 09, 2011 | Computers & Internet
Can't dowload picture to computer from Canon EOS 550D
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Apr 18, 2012 | Canon EOS 550D Rebel T2i Digital Camera
I think i used the wrong disc to install windows on my dell dimension 2400. its stuck on 16-bit mode and the resolution won't change from the 800x600? and i can't connect to the internet, but my...
Hi there, On your laptop that can get on the internet, go to www.dell.com/support and download drivers for your Network Card and your Video Card from that site. Make sure you put in the right model number (dimension 2400). Transfer them to a USB key, and move the USB key to your desktop. Install those drivers and everything work will again. You may need to install additional ones as you see other things not working (like audio). If you need more help, let me know. -Alex
Aug 13, 2011 | Dell Dimension 2400 PC Desktop
YES! I HAVE A LENOVA LAP TOP COMPUTER WITH WINDOWS 7, AND IT IS NOT COMPATIBLE WITH THE "OLYMPUS" DIGITAL VOICE RECORDER "VN-2100PC". IT WORKED ON MY DESK TOP "DELL COMPUTER"...
You can download the drivers for you VN-2100PC for Windows 7 from Olympus's website. I've linked it below.
http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1270&os=w
Thanks! I hope that solves your problem.
Jun 09, 2011 | Computers & Internet
My MSI MS-1683 Laptop With Windows 7 Home Premium won't boot up right. When I hit the power button, it loads to the screen that says "MSI" and then to a screen that has an underscore that...
That blinking underscore is the way in which the laptop's BIOS is telling you that it didn't find any Windows to boot to - it was completely corrupted.
The only thing left to do is to reinstall it.
May 29, 2011 | Computers & Internet
128 people viewed this question
k24674
