Question about Garden
I have an older 12 hp tecumseh engined ride-a-mower I didn't use it for 2 years. This year I replaced the battery and the spark plug but can't get the engine to fire . What should I be doing next??
  • 608 Answers
Hi, you will need to drain the old fuel and clean the carby including all jets. Regards Phil.
Posted on May 25, 2011
I have a Troy-bilt riding mower with 20 hp Kohler engine. Battery was going bad but I was able to charge a few times successfully. The last time, the seat fell forward onto the charging battery and
Okay according to the electrical diagram the lights are powered by the alternator only when the engine is running so the engine must be cranking. If so then you may have somehow reversed charge the system. If so then the ignition coil would be blown and possibly even the alternator depending the engine setup. It doesn't take much more than momentary reversal to do this. When cranking test for spark at the plug gap while is removed and grounded. If no spark I would think the coil has died. If you getting a spark then check fuel cutoff solenoid on the carburetor to see if it working even a reverse 12 volts won't hurt it.
I am including a copy of the electrical diagram so you can do electrical checks on the system, Good Luck
Electrical Diagram
Nov 15, 2014 | Garden
Is it hard to change a magneto on a 5.5 hp Tecumseh engine?
How old is the gas in the tank? If it is older than 2 months drain it out and put in fresh gas and try again. Have you seen spark jump across the spark plug gap? To check for spark I use a spark checker. One end goes to the plug and the other to the spark plug lead. If you have spark you see a light flash which is more easy to see.
Sep 16, 2014 | Tecumseh Engine 5.5hp Horizontal OHV MTD...
How can i get engine started
Make sure the spark plug is connected
Use only highest octane gas
throw out /drain any old gas from last year
check and add oil
change the spark plug
clean the air filter or replace it
check that fuel injection lines and port holes are not plugged
if that does not work go to dump and get a new one cheap from discarded mowers that had a cheap broken deck.
Aug 16, 2014 | Tools & Hardware - Others
6.5 toro self propel.....new plug and new gas,,,turns over but then shuts down...replaced both neoprene hoses
Carburetor Cleaning TUNE UP of Toro 6 5HP Lawnmower with Tecumseh Engine
The above link will provide a video on how to clean the carb on the 6.5 hp mower. Before you go to that length, try putting some carb cleaner in the fuel tank and see if that corrects the problem. Also, as the video shows, make sure the spark plug is getting a good spark. If the spark is weak , the fly wheel may be rusted, ot the magneto is bad.
May 09, 2014 | Garden
No spark on my murry riding lawn mower it has a tecumseh ohv135 replaced the spark plug
clean the flywheel, and the contact area on the coil. if this doesn't fix it then you need a new coil.
Nov 03, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I have an ariens Fairway model riding mower won't start
DISCONNECT THE SAFTEY SWITCHES FROM THE ENGINE STOP SW. MAKE SURE THE ENGINE HAS SPARK.THEN DO PROCESS OF ELIMANTION
Sep 22, 2009 | Garden
New 12hp tecumseh engine won't fire
IF THE ENGINE WILL TURN OVER WITH THE KEY YOUR PROBLEM LIES WITHIN THE ENGINE ITSELF
PULL THE SPARK PLUG AND LIE IN ON A GROUNDED SURFACE WITH WIRE ATTACHED TURN ENGINE OVER AND VISUALY CHECK FOR SPARK
IF STILL NO SPARK YOU WILL NEED TO PULL FLYHEEL TO CHECK POINTS AND COIL
IF YOU NEED ASSISTANCE IN THESE PROCEDURES LET ME KNOW
Sep 19, 2009 | Garden
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
