Question about Archos 605 WiFi Digital Media Player
Archos 605 not being recognized
Hey, in the process of trying to correct this issue on my own, I stumbled across your posting about this from earlier this year. Did you ever yours fully properly working again, and if so, how? I saw that you used the MS AutoPlay Repair download; what exactly did you do when using it? Did you run the program with the Archos still in PC Harddrive mode and leave it that way, or did you switch it back over to Windows Media Device when it asked you to recreate the Autoplay problem?
    New Friend:
  • 161 Answers
I think most of the problems come from the fact the archos unit gets to hot, leaving it plugged into the docking station for charging and downloads does not help. Try leaving it to cool down overnight then plug it in next day. My PC recognized it as A605 straightaway. My pc is still in hard drive mode and when plugged into the pc it recognizes it as an Archos A605 unit and can be adressed as normal.
Posted on Sep 08, 2008
SOURCE:
207 error code
Download the latest firmware for Archos 605 WiFi to your PC.
Connect your 605 to PC and copy the film across and unplug 605 from PC.
I take it you have tried to update it and this happened.
It has happened to others too, they redownloaded and tried again and it worked.
Hope this helps, if it does then reply here please.
Aug 30, 2012 | Archos 605 WiFi Digital Media Player
CProblems onnecting Archos 700 after connecting 605 to PC
It is very possible the drivers conflict. You should try uninstalling everything to do with the one you don't want. Then install the drivers/software for the 700. Also what software are you using and what version?
Thanks,
Lee
Sep 21, 2008 | Archos AV700 Digital Media Player
605 not recognized by Windows Media Player 11.0
You may require a driver to work with your device. Try downloading driver from company's web site.
Jul 15, 2009 | Archos 605 WiFi Digital Media Player
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 20, 2009 | Archos 605 WiFi Digital Media Player
My archos 605 has got recovery code 102 and i cant get it to conect to my pc to fix it can u halp
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
Mar 19, 2009 | Archos 605 WiFi Digital Media Player
Getting a white screen with 102 error message
Mar 13, 2009 | Archos 605 WiFi Digital Media Player
ARCHOS 605 CANNOT START CODE 10
try to reboot your pc, reinstall drivers this should work
Feb 06, 2009 | Archos 605 WiFi Digital Media Player
ARCHOS 605 30MB SLOW INTERNET SPEED and OPERA BROWSER CRASHING: Speed tests from Speakeasy.net show download speed less than 300Kb/s and up load speed is 127Kb/s, while an adjacent wireless laptop...
How do I get internet away from my house on my archos 605 wifi, I can get it on my BTHUB in the house, is there a list of HUB I can conect to. when I try to conect a list comes up but they are all locked
Nov 11, 2008 | Audio Players & Recorders
Archos 605
I've posted this solution a few times now........go into Disk Management on your pc and allocate a drive letter to the Archos.
You should then be able to see it.
Sep 30, 2008 | Archos 605 WiFi Digital Media Player
PC no longer recognizes my Archos 605
in the archos....select SYSTEM....change windows media player to PC Hard Drive and this worked for me
Mar 24, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 WiFi Digital Media Player Logo
262 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
