Your LCD inverter has gone bad. They are relatively cheap and easy to replace. CLICK HERE to go to a page to see what it is and the price. With the laptop open look at the frame, or "bezel" around the edge of the screen. There are usually 6 or 8 screws (depending on the model) that attach it to the lid. The inverter is in the middle on the bottom of the LCD. You can access it by removing the bottom half of the screws and carefully pull the bezel out and away. (you may need to take all screws out and remove the bezel completely) The inverter is held on by 1 or 2 screws and plugs in at both ends. Just unplug, remove, and replace. Very easy to do.
Seems like the backlight of your LCD is already failing, you need to replace it.
Hope this helps.
