Question about Philips MMS 321 Computer Speakers
Just plugged my speakers in an i have only sound from the tower
  • Philips Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 25, 2011
Where is the speaker bar plug on a dell monitor
This plugs into the tower unit sound output. It is on the back of the tower and will have a speaker icon. There is no sound out on a common dell monitor.
Jun 02, 2014 | Dell AS500 Sound Bar Computer Speakers
Z313 no sound
Phone plug on subwoofer plugs into phone jack on back of tower! Plug and jack are color coded green. If you plug into wrong jack you get no sound or intermittent sound. Also speaker cables have an on-off swith so make sure you are switched "on" or you will not get sound.
Oct 30, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
Where do I connect the speakers to the monitor. I have a Flatron L1922P monitor. I ordered 2.0 USB Multimedia speakers that come with a 3.5mm stereo plug and USB plug. I must not being doing something...
Your speakers do not plug into your monitor. Your speakers should be connected to a USB slot on your PC tower and the 3.5mm stereo plug should be put into the green stereo jack on your PC tower. If your audio jacks on your PC are not colour coded, then you should look for the jack which has a picture of a set of earphones over them.
Depending on your speakers, you may or may not be required to keep the stereo plug connected in order to get sound. Some models transmit model over the USB connection and others just use the USB connection as a way to supply power to the speakers and need the stereo plug to be connected in order to have sound. I suggest trying both.
Mar 25, 2011 | LG L1922P 19" LCD Monitor
I cannot get any sound from my speakers or the monitor speakers. I have plugged the green cable to the monitor and to the green connector on the tower with no luck. I have also plugged the extra speaker...
It sound like you have connected them correctly however unless they are multi-channel speakers you should only have to connect the green cable. Check to see if the volume control on your speakers/monitor and also OS are turned up and not on mute and also check to see that you have sound drivers installed for your sound device/card.
Oct 23, 2010 | Acer Aopen MS698 Computer Speakers
Only the sub anbd one of the four tower speakers
The center one, right? You need to plug in all 3 plugs in the sound card, otherwise they won't work.
Feb 16, 2010 | Dell 5650 Computer Speakers
Can I use mediamate speakers I had on my desk top on my laptop that runs vista? I have them plugged in and it sounds terrible...I have always had a problem with these speakers being very crackly and...
No it is not fixed, I think it has to do with the wires and plug that goes into the tower, when I move the plug in the tower around I get good sound, can't fiddle around all day with wires,and holding the plug in a specific location, I think they are junk... and I don't think the speakers justify spending money on trouble shooting!
Joyce
Jan 28, 2009 | Bose MediaMate Computer Speakers
Muffled sound
plug it in properly and replace the internal speaker- simple
Jul 16, 2008 | Apple (6612068) Sound Card
No sound from speakers
If you buy a 1/8 - 1/8 male on each end of cord and plug it into your stereo headset plug on your computer (probably the front of tower) and the other end to the analog in on the back of your ba735 will work great....... Good Luck,
Regi
Mar 20, 2008 | Boston Acoustics BA735 Computer Speakers
Philips MMS 321 Computer Speakers Logo
48 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
