Question about Clarion VRX745DVD Car DVD Player
My flex ribbon broke. do you need to completely open it to change a new flex ribbon?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Clarion Master
  • 2,226 Answers
Yes you do.
Posted on May 26, 2011
Where to buy flex ribbon cable
To start with you will need the complete model number for example
LN52A630A3FXZA 14 DIGITS AND A VERISON NUMBER WHICH HAS 4 DIGITS.Or better yet the part number could be looked up with the correct serial number which always has 15 digits on a samsung tv. And by the way the part is called a LVDS CABLE THANKS JOHN
Aug 22, 2012 | Samsung Televison & Video
Premier deh-p960mp
Not properly in place the screw / the unit cover to exact point..
Apr 14, 2008 | Pioneer Premier DEH-P960MP CD Player
The screen on my phone went black. I cant read any text messages. I can receive calls though.
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jun 28, 2010 | Motorola Mobility RAZR V3
I have a Motorola Razr V3. Very recently the exterior and main screen went black. The phone itself still works (I can still call people and receive calls) but I can not see anything on the screens. Do you...
The reason your phone interior and exterior screen went black is because there is a problem with the flex of the phone.
The flex is the mechanism like a ribbon that connects the screen to the panel of the phone.
All you have to do is to replace the flex of the phone.
To replace it on your own, the process to do this are as following;
  1. Get the appropriate screwdriver (Torx 5 screwdriver).
  2. Remove the four rubber stoppers surrounding the screen to reveal four screws. Remove these screws.
  3. You can now remove the front cover. To do this, use a credit card to lever the cover up. The cover clips on and the levering motion will unclip it. Start at the top, then unclip the cover at the bottom, then both sides.
  4. Now detach the camera from the phone. Simply pull the ribbon away from the phone to release it.
  5. Now unplug the other ribbon. The ribbon attaches like a plug and socket. Simply lift it up to unplug it.
  6. The ribbon you just unplugged is the flex of the phone, so you have to unscrew the lower part of the phone to remove it completely.
  7. To open the lower part, you have to open the back cover and remove the battery,
  8. Unscrew the screws you see, than split it open with a credit card or the tip of your finger, apply a little force to open it.
  9. Then unscrew the board, you will see where the other end of the ribbon is connected on the board, then you can remove it and fix a new one.
  10. Reverse the process to reassemble the phone together.
Take care
Jun 22, 2010 | Motorola Mobility RAZR V3
My phone was just working fine n when i flipped it
Hi the most likely cause of your problem is going to be with the ribbon the sends the data from the circuit board to the screen, the problem you have is this isnt a part you can change yourself so would need sending off to have fixed.
the reason this part fails is down to the fact that its a flat piece of ribbon but when you close the phone the ribbon then bends in the middle so every time you open and close the phone this ribbon is bending as its made to do, how ever over time this bending causes the little copper wires in the ribbon to fail giving you the white screen you are getting.
So im sorry i cant give you an easy fix for your problem because its going to be a case of getting new parts and having them fitted, doing this would then get your phone working again, the only problem is you need to see if the cost of repair would cost more then the phone is worth. If you really want to keep the phone then shop around for the cheapest price you can get, its not a hard job to do and would only take 10min or so to replace the part how ever you cant do this work yourself as you need specialist tools to remove the casing and the ribbon.
Apr 20, 2010 | Motorola Mobility RAZR V3
Replaced the screen but there is no image coming up, just a lit up black screen.
if you could see any image from the broken lcd before changing it so your new lcd is not working or no installed right
and if not you may try the cable or the hard shock that broke your lcd effected the main board
May 06, 2009 | LG Shine CU720 Cellular Phone
Faceplate stays half opened, half closed will on not turn
I have the exact same problem. I called the Kenwood tech line and the tech reported that the ribbon cable is probably broke. It is the flex cable between the head unit and the rotating face plate. He said it's not an expensive fix but we would need to mail it to a service center if you're like me and not near one. I just replaced mine with a new unit. It was about time anyways.
Nov 21, 2008 | Kenwood KRC-X858 Cassette Player
Experts., pls help.! i beg you
check new flex ribbon cable if not solve the probe check new lcd if not working
get the phone to the nearest phone repairshop in ur area and tell him flash my phone
ok rate this post and give me ur feed back
Oct 28, 2008 | Nokia 3230
Help!!
SGH-D500 white screen'
when you turn on your phone and the screen is white' even you restarts and nothing change' make sure that your phone is can recieve and you can make a call' the prob. is the flex ribbon of your phone, there is a flex connected in the LCD to the board' or the machine. D500 phone always having this prob, all sliding and flip phone having this prob.
by replacing the flex ribbon' you can solve your prob.
by a skilled cellular technician.
Jan 06, 2008 | Samsung SGH-D500 Cellular Phone
Clarion VRX745DVD Car DVD Player Logo
163 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
