Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY kv32fs1201. 1) IC001 is faulty (M board) 2) Screen (G2) is improperly adjusted. How might this be fix and o can i have a bit more of an explanation
    Genius:
  • 1,126 Answers
Set all you menu settings nto mid,range, and then turn the screen voltage (G2) up swoly to the point where you start to see retrace lines and back it off where the lines are gone.
Posted on May 25, 2011
Sony TV set, KV20FS120 BA6 chassis: light blinks, set isn't coming on. Why?
Sony sets like this have a built-in self-diagnostic function.
The blinks of the Standby LED are the self-diagnostic codes.
There may be more than one error. The blinks indicate only the first error.
Unlug the set. Wait 30 seconds.
Prepare to count the number of times the Standby LED blinks.
Plug the set back in. Count the blinks.
2 blinks
  • Diagnostic Item Description: +B overcurrent (OCP)
  • Probable cause:
    • H.OUT (Q506) is shorted. (A Board) (20"/21" models only)
    • RGB Amp (IC1751) is shorted. (CV Board)
  • Detected Symptoms:
    • Power does not come on.
    • Load on power line is shorted.
4 blinks
  • Diagnostic Item Description: I-Prot
  • Probable cause:
    • +13V is not supplied. (A Board)
    • IC545 is faulty. (A Board)
    • Has entered standby state after horizontal raster.
    • Vertical deflection pulse is stopped.
    • Power line is shorted or power supply is stopped
5 Blinks
  • Diagnostic Item Description: IK (AKB)
  • Probable cause:
    • Video OUT (IC545) is faulty. (A Board)
    • IC001 is faulty. (A Board)
    • Screen (G2) is improperly adjusted.
    • No raster is generated.
    • CRT Cathode current detection reference pulse output is small.
The above may be of little help. Your best bet is to download the service manual for the KV20FS120.
...Google search: Sony KV20FS120 service manual
Apr 26, 2016 | Sony Televison & Video
I HAVE A SONY-KV-ES34M61TV,PICTURE GOOD,SOUND GOOD BUT LIGHT BLINKIG FIVE TIMESWHEN NOT PICTURE ON TV SCREEN FLESHING LIGHT IS STOP, PICTURE GOOD,SOUND GOOD BUT IN SELF DIAGNOSTIC SCREEN DISPLAY 005:255,IT...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 11, 2015 | Sony Televison & Video
Projection TV Sony, first power on only hear the sound for couple second then turn off. Stand by light keep flashing 5 times. What's wrong and how to fix?
  • 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
Jul 18, 2014 | Sony KP-51HW40 51" Rear Projection...
RED FLASHING LIGHT
sir
these are the causes for 5 red blink in your modal
Video OUT (IC1545) is
faulty. (A board)
• IC001 is faulty. (A board)
thanks
Oct 03, 2017 | Sony Televison & Video
Sony kwp 65hd1 timer/stand by blinks 5 times over and over
what it means is usually near or at the crt boards.
This model may have the on screen error buffer:
With set off use the sony remote:
Display, 5, vol down, enter, and power
if it has it a box will appear in middle of screen
Let me know if box appears if any item there has a number--they should all be at zero to the right of each.
Mar 12, 2012 | Sony KWP-65HD1 TV
SONY KV-XF21N90 WON'T TURN ON, Blinks 5 times
5 times flashing light shows following possible problems in your tv..
• G2 is improperly adjusted.
• CRT problem.
• Video OUT IC1800 is faulty.(C5 board)
• IC301 is faulty. (A board)
Most probably cause is G2 voltage adjustment. If you know how to do it, please go ahead or look a tv tech around.
Regards,
Sep 04, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Red screen then shuts off
icon1.gif Posted: 2008-06-16 14:04
Hi TroyK,
Jehill is on vacation until June 22nd. So he should be able to reply after that date.
I did find a similiar thread on this issue that Jehill responded to
http://www.agoraquest.com/viewtopic.php?topic=31515&forum=34
For the KP46WT500, 5 blinks, pause, 5 blinks, etc. means "White BalanceFailure (Not Balanced)" and the probable cause locations listed are asfollows:
1. Video OUT (IC7101, IC7201, IC7301) is faulty (CR, CG, CB boards)
2. CRT drive (IC309) is faulty (A board)
3. Screen (G2) is improperly adjusted.
These are starting points for a qualified service technician.
Claudio
May 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony big screen 5 blinking standby lights
5 blinks is a white balance failure here are the most possible causes.
Video OUT (IC9101, IC9201, IC9301)
is faulty. (CR, CG, CB Board)
CRT drive (IC452) is faulty.
(A Board)
G2 is improperly adjusted.**
If you need more info let me know.
Apr 10, 2008 | Televison & Video
BLINKING 5 TIMES, NO VIDEO, NO SOUND
Hiii...
Try to check the M board ? IF you have the BA-6 Chassis....5 times blinking on selft diagnostic means : No raster generated,IC001 fault,need to adjust the G2 (screen) voltage around 170V +/- 10%...
Hope can help you...
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Mar 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
150 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
