I HAVE A 52" ZENITH
  • 11,800 Answers
There are several models on several generations of Zenith manufactured LCD projection tv's. Without knowing the exact model of yours i can't be sure but in most of them the Lamp life counter is reseted this way: with the tv in stand-by, you press the "?" key on the remote then immediately you press 9,8,7,6 and then the OK. If the procedure was correct the 3 lights on the front of the tv will blink to signal the end of the reset procedure.
In others , hold down the Mute button on remote and Enter on TV at the same time for a few seconds, you should get a screen prompt asking if you want to reset the timer for the lamp.
Posted on May 25, 2011
Zenith E44W46LCD TV power/operation indicator lamp blinks green then goes red when power switch pressed. I can hear the fan motor but no picture. No history of lamp indicator warning.
If the tv projection lamp already been inside the tv now like a 1 1/2 or 2 years?Tv used it every day like 4 or 5 hrs every days?Yes?Than it is the tv projection lamp have to be replace,because the tv projection lamp life span have ended.
Sep 04, 2011 | Zenith E44W46LCD 44" Rear Projection...
Blue images on lcd tv
optical block failure
Feb 22, 2010 | Televison & Video
Zenith 52" LCD. When the lamp goes out does the sound go out also? Tv wont turn on and the power and lamp light flash red. no sound.
Has Lamp been replaced? Also if Blaster board is bad Lamp will not turn on also CK Fan behind Lamp If it is not running Set will not turn on For Parts Try Encompass 1-800-639-3328 or look on line www.Encompass Parts, Also Look on E-Bay for Lamp and Blaster Board I found Lamp fot mine for 85.00 and blaster board for 55.00Type in Model number it will be on back of your TV.
Nov 10, 2009 | Zenith D52WLCD 52" Rear Projection...
3rd lamp purchased within 2 yrs
There is a slight chance that you might have an issue with a defective ballast, I mean 3 lamps in 2 years, it's too much. The best way to go here is replacing the ballast, that might solve the issue.
Jul 25, 2009 | Mitsubishi WD-62327 62" Rear Projection...
My zenith 52 wlcd-tv will not come on.
We had the same problem and cost 374 dollars and the remote control thing in the TV was replaced in our 52 inch projection tv (about 6 years old). Now it does not turn on with the cable remote. 2 months later now the tv (on its own starts to flip channels and the volumes goes up and down even when the all the remotes do not have batteries in them.
Feb 03, 2009 | Zenith R57W46 57" Rear Projection...
ZENITH D52WLCD
I just found the solution on another model of Zenith TV. Hold the enter button down on the TV and the MUTE button on the remote. In approx. 5-7 seconds a screen will pop up asking if you want to reset the lamp timer. Hit the bullseye button in the middle of the arrows and it will reset. Worked perfectly.
Apr 15, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith model #m52w56lcd tv?
For a really good step by step with pictures guide to replace it go to
http://www.fixyourdlp.com/blog/?p=34
For a good place to purchase the lamp go to http://www.discount-merchant.com/Original-Zenith-Projection-LCD-TV-Replacement-Lamp-p
/zenith_m52w56lcd_lamp.htm
I have found they have the best price on these replacement lamps. You might also check Ebay.
Feb 21, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith HD 44 inchr red lamp light is on
sir,,,maybe,,,,,but you said your tv is ok soo i think its just alright,,,thnkss
Jan 29, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith Lamp Light on
When the lamp is replaced the lamp timer must be reset. The timer is set for just so many hours and then the warning lamp is illuminated. The only way to reset the lamp that I am aware of is with a zenith programmer remote. Perhaps you can find a local lg/zen service center to allow you to use a programmer and instruct you on resetting the timer.
Reset lamp clock
you need to reset lamp timer this is to tell set it now has new lamp i have the information at my shop as soon as i can , I will up date this with how to reset timer.
Dec 29, 2007 | Zenith D52WLCD 52" Rear Projection...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
